Author Topic: Key Fob replacement ideas  (Read 3854 times)
Offline fazi123
« on: May 08, 2014, 11:38:58 pm »
Hi guys,
My 2 key fobs are looking pretty tired, and was wondering if there was a recommended fob / casing you guys use in order to bring them back to life?
Thanks,
Faz
Offline Wooosh
  • -Receive: 87
  • Factory ponies.
Stage 2 MK5 GTI Revo GONE
Stage 1+ MK5 GTI R-Tech GONE
Offline PatchySan
  • -Receive: 59
  • Gracie!
Re: Key Fob replacement ideas
« Reply #2 on: May 09, 2014, 12:52:44 am »
I just use the blank VW key fobs from eBay, not expensive (can be had for under a fiver) and generally is straightforward to swap over the remote board, blade and immobiliser chip. The only thing you need to watch out for the the spring mechanism that flips the key, it can be easy for it to spring out for freedom! Disassembly instructions can be found here - http://www.my-gti.com/2766/change-battery-in-folding-key-with-remote-control-for-volkswagen-golf-jetta-passat-rabbit-and-gti
Offline Jomty
« Reply #3 on: May 09, 2014, 07:31:00 am »
http://www.ebay.co.uk/itm/Genuine-VW-GTI-Key-Cover-/171225348056
£26 for a key fob cover!? Jesus. Might look at a new fob though, mine are looking a bit worse for wear too.
Offline PND
  • -Receive: 62
« Reply #4 on: May 09, 2014, 07:35:24 am »
If it's just your buttons that are worn, get one of these.  You obviously have to take the original fob totally apart to remove the buttons section, but it's easy and looks like new once done.  Bargain!  :happy2:
http://www.ebay.co.uk/itm/250776250647
Offline Wooosh
  • -Receive: 87
  • Factory ponies.
« Reply #5 on: May 09, 2014, 08:39:40 am »
Bit pricey I agree, but looks good IMO. :happy2:
Offline JaseGti
    • Remoteclothing
« Reply #6 on: May 09, 2014, 09:08:52 am »
I've just bought some replacement buttons
At that price it's a bargain
CW is the way forwards
Remoteclothing.com
Offline Lewis
« Reply #7 on: May 11, 2014, 06:55:15 pm »
There is plenty of cheep ones on eBay from China. They take about 2 weeks to arrive after ordering, but they only cost about   Fiver and they look great.
Offline J12spk
  • VW PERVERT
« Reply #8 on: May 11, 2014, 09:23:11 pm »
I was too scared to do this as I read somewhere that a guy couldn't get his transponder chip out and damaged it! Ended up going to the stealers for £160 new key
Das Auto
Offline MJ
« Reply #9 on: May 11, 2014, 09:42:40 pm »
I bought 2 new cases off eBay from a uk seller. Took about 15mins to swap, fitted new batteries and now I effectively have 2 new keys.
Unless the transponders have been glued in you should have no issues.
2005 VW Bora TDI 130 Highline auto. Current mods: 5.5lt washer bottle & black and aluminium A/C knobs & 312mm front brakes and 256mm vented rear brakes.
Next: turborevs SMIC, 20vt pancake pipe and silicone connectors.
VCDS, ODIS, VAS - PC and multi brand diagnostics around Manchester - pm me for help and advice
Offline J12spk
  • VW PERVERT
« Reply #10 on: May 12, 2014, 06:42:11 am »
Nice 1 MJ! I might check first!
Das Auto
Offline bbfb10
« Reply #11 on: May 12, 2014, 08:28:55 am »
If your transponder is glued in nail varnish remover should unstick it.
Full VCDS Hex + Can.
  • -Receive: 291
« Reply #12 on: May 12, 2014, 08:34:02 am »
Will that work? I bought a blank keyfob off ebay to switch things over. Everything was easy except for the transponder. I didn't fancy chipping away at the glue with a knife because knowing my luck it would break/damage the transponder.
Offline MJ
« Reply #13 on: May 12, 2014, 09:29:45 am »
Nail varnish remover, super glue remover or thinners all work well.
Offline Mullan
« Reply #14 on: May 15, 2014, 06:46:58 am »
So the keys don't require re programming when being taken apart? That's just a myth?
