Author Topic: Water meth injection  (Read 11852 times)
Offline Jussa
  • Bicester
Re: Water meth injection
« Reply #15 on: May 12, 2014, 01:11:41 am »
The WMI kits themselves aren't that expensive, it is the labour involved to fit them. Worth every penny mind in my opinion.
Please elaborate  :booty: :booty:???
Elaborate on the installation or performance gains???  :P
Offline betty_swollox
  • -Receive: 29
« Reply #16 on: May 12, 2014, 08:52:14 am »
I was going to go back and ammend me comment but couldnt be arsed
Just want to know what every one thinks about the gains. I don't have revo software so being able to change the timing etc is of no use to me lol
2010 Leon CUPRA
BCS Powervalve Exhaust
Revo Ceramic Intake
APR Stage 2
Offline dokez
« Reply #17 on: May 12, 2014, 12:45:58 pm »
It certainly helps, as for no Revo. You'll have to get custom map or alternative use APR race map which I think is 105octane.
This is to make use of the meth.
  • -Receive: 29
« Reply #18 on: May 12, 2014, 12:51:27 pm »
Already got APR, so getting that changed is no problem ;)
2010 Leon CUPRA
Revo Ceramic Intake
APR Stage 2
Offline dokez
« Reply #19 on: May 12, 2014, 05:58:15 pm »
I believe its the 105 octane map. They do ask you sign a disclaimer because your technically not using race fuel.  This is knowledge from a friends ED30 with WMI/APR MAP.
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #20 on: May 12, 2014, 06:14:13 pm »
R-tech will tune for WMI. See what they did with James's car here. 401bhp
http://www.mk5golfgti.co.uk/forum/index.php/topic,43854.msg624693.html#msg624693
Just shows what is possible with a K04 and the right hardware  :laugh:
http://www.mk5golfgti.co.uk/forum/index.php/topic,43854.msg518465.html#msg518465
And on JKM's rollers it made more power than some big turbo cars with an immensely flat power curve (no boost controller used here)
http://www.mk5golfgti.co.uk/forum/index.php/topic,43854.msg630125.html#msg630125
« Last Edit: May 12, 2014, 06:16:30 pm by GrayMK5GTI »
Offline dokez
« Reply #21 on: May 12, 2014, 06:16:54 pm »
look what happened
wasnt this because of the high tune ?
« Last Edit: May 12, 2014, 06:19:03 pm by dokez »
Offline toosmiles
  • -Given: 22
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,92286.0.html
« Reply #22 on: May 12, 2014, 06:19:12 pm »
Ouch that's putting me off now
Golf R mk6 R-tech tuned GTX3071r
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #23 on: May 12, 2014, 06:30:33 pm »
He asked Niki for an all out tune to see what the engine could cope with. Niki wouldn't do this level of tune unless you were happy to take the risk. This is the result of 450lb/ft of torque.
It was a BWA engine which is known to only take about 360bhp with corresponding torque. A BYD/ CDL engine can take 400+bhp all day long.
  • -Receive: 29
« Reply #24 on: May 12, 2014, 06:32:43 pm »
i am safe then lol
2010 Leon CUPRA
Revo Ceramic Intake
APR Stage 2
Offline mvb12
  • -Receive: 64
« Reply #25 on: May 12, 2014, 06:34:20 pm »
I was speaking with the same guy about this a few days ago. basically the Mixture is 50/50 split to enable him to run it at the 104octane setting. does any one know if REVO have a 104 file for the "general customer"
P.S - If I go the WMI route I would want my kit in the front. this will cut half the time of the set up too  :laugh:
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #26 on: May 12, 2014, 06:36:54 pm »
i am safe then lol
Yes  :smiley:
James fitted a CDL lump (see further on in his build thread) and it's happy now.
It was good of him to prove how strong the BWA engine is  :congrats:
Offline mvb12
  • -Receive: 64
« Reply #27 on: May 12, 2014, 06:37:31 pm »
Is this correct - a lot of guys have BWA engines make the KO4 conversion slap on meth and are fine running slightly more or so i'm lead to believe.
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #28 on: May 12, 2014, 06:39:52 pm »
It's all down to the torque, that's what kills engines. 360bhp is usually known as the safe limit
Offline dokez
« Reply #29 on: May 12, 2014, 06:43:01 pm »
Was you at BHP by any chance?
AEM recommend to only use 50/50 mixture.
Revo is just allows you to alter the the map by up the timing. I can run timing 7 where before i can only run 5. Def feel more of a kick but nothing to boast about. But for £300 its def a good mod, keeps engine temps low especially on those track days.
This is what me and my mate did, Under the passengers arch with the pump. Easy to top up  :happy2:
Cables go through the bulkhead and straight behind the glovesbox, from there you can wire your controller where ever you want to.
Longest part is the throttle body removal, very tight on the back bolts. Easy option is to get the revo pipe.
