Author Topic: Rear caliper problem  (Read 658 times)
Offline chrispygti
« on: May 10, 2014, 12:53:04 pm »
Hi All,
Upon driving today, my rear caliper has started to make a very nasty sounding noise. It sounds like a aeroplane!
I've had a look and it's the passenger side rear and the disc now looks like it's starting to leave a pitting in the disc.
Does this sound like a replacement rear disc and caliper job? Is there anything I can do as a quick fix to tie me over until Monday as I'm actually not at home at the moment as helping with a move.
Any suggestions would be really appreciated, I am a bit concerned about driving it still however there's no obvious effects on the braking power at the moment.
Offline paulw123
  • -Receive: 47
Re: Rear caliper problem
« Reply #1 on: May 10, 2014, 02:50:59 pm »
have you just worn the rear pads down to metal, so metal on metal grating?  if so get new pads on quick before the disc is knackered as well.
Offline chrispygti
« Reply #2 on: May 10, 2014, 04:19:52 pm »
In all honesty, I'm not too sure. I would think its
More the caliper is sticking to the disc?
Offline Carnegti
« Reply #3 on: May 10, 2014, 05:09:45 pm »
Is it still sticking now? Mine did this once and it turned out a stone had flicked up
Off the road between the caliper and the disk and the break bound on.
Offline V2 FAN
  • Porsche 911 inbound
« Reply #4 on: May 10, 2014, 05:12:42 pm »
Could be a sticky piston ?
Potential rebuild or a cheap substitute from ebay
Offline Rampage
« Reply #5 on: May 10, 2014, 08:39:07 pm »
^^^ could be this or a sticky/seized slider on the caliper
Offline DDM
« Reply #6 on: May 11, 2014, 01:07:38 pm »
i'd jack the wheel up and make sure it spins, if it dosn't i wouldn't drive it, it'll eventually boil up the brake fluid, if this happens the brake pedal will go to the floor without any braking resistance.
