Author Topic: retrofitting heated washer jets  (Read 786 times)
Offline flyboy1976
« on: May 11, 2014, 06:10:55 pm »
I've got the kit from kufatec but their instructions are a bit vague. Does anyone know if the live goes to Connector A or B on the BCM.
I've heard conflicting info so need someone to give me the heads up on which connector and what pin number. How do you test the nozzles as well?
Cheers in advance
Offline Lewis
Re: retrofitting heated washer jets
« Reply #1 on: May 11, 2014, 06:46:40 pm »
Sorry if I'm not supposed to do this, but how do you know if your car already has them fitted?
Cheers.
Offline flyboy1976
« Reply #2 on: May 11, 2014, 07:14:12 pm »
Where the washer jet fluid pipe goes through the rubber grommet under the bonnet you will have wires running next to the piping and if you pop off the jets the have a 2pin wiring plug attached to them.
Offline Lewis
« Reply #3 on: May 20, 2014, 09:12:11 pm »
Thanks for the info  :happy2:
