Author Topic: O2 Sensor (Lambda) PN  (Read 4517 times)
anorganix
« on: May 12, 2014, 08:42:04 am »
Hi,
I'm having some trouble with the precat Oxygen sensor on my S3.
From the 2 error codes I have, it seems that the sensor is toast & I'm looking for the part number if anyone can help.
Started with rough/variable idle after cold start and no MIL.
After I restarted the engine MIL came on & idle is stable - car seems to run properly.
Any advice is appreciated.
Thanks!
  • -Receive: 453
Re: O2 Sensor (Lambda) PN
« Reply #1 on: May 12, 2014, 09:39:01 am »
Assuming it's the same sensor as the gti then 06J906262AA
  • -Receive: 453
« Reply #2 on: May 12, 2014, 11:56:00 am »
anorganix
« Reply #3 on: May 12, 2014, 12:56:20 pm »
Thanks for the tips!
Found a new OEM one at 100 quid incl. P&P.
 :drinking:
« Last Edit: May 12, 2014, 12:59:16 pm by anorganix »
Offline suf
« Reply #4 on: January 29, 2018, 02:27:38 pm »
Just curious - if you have a lambda fault code/engine check light, but my car has been running fine. Is it still crucial to get it changed or can one just live with it ? Whats the worse that can happen ?
