Author Topic: whistling sound under hard acceleration  (Read 3445 times)
Offline edjbreeze
« on: May 12, 2014, 02:03:02 pm »
So I've had the golf for 3 months now, and have sorted most of the problems. My last one, and most annoying is a loud whistling noise that only appears under mid/hard acceleration between 3/4k revs??
there is no loss of power anywhere on the rev range, just a loud high pitch whistle. I don't get it on gentle acceleration or anywhere else on the rev range?
I'm running a k&n typhoon and have checked it for any cracks or loose connections but nothing??
anyone had anything similar? Or any advice?
cheers
anorganix
Re: whistling sound under hard acceleration
« Reply #1 on: May 12, 2014, 02:15:43 pm »
I'd check the DV first, it's easy to access.
Same whistling like this?
« Last Edit: May 12, 2014, 02:31:53 pm by anorganix »
Offline v4rley
  • -Receive: 104
« Reply #2 on: May 12, 2014, 02:24:53 pm »
Believe it's a tail-tail whistle of a K03 turbo, it's noticeable once a intake is added. The standard intake / engine cover was manufactured to mask the sound I read somewhere :happy2:
I have a k03 GTI and has the same symptoms... Have to learn to love it
Offline edjbreeze
« Reply #3 on: May 12, 2014, 03:03:53 pm »
It does sound like the video however i replaced the dv straight away.
i guess it could be a faulty dv, I'll try another. If not then i guess I'll just learn to live with it.
« Reply #4 on: May 12, 2014, 03:22:52 pm »
Probably normal with that intake.
Offline edd666999
  • -Receive: 89
« Reply #5 on: May 12, 2014, 03:31:38 pm »
I had more of a screech than a whistle...that was my turbo.
Post a video up lets have a listen.
