Author Topic: What is the maximum MAF reading?  (Read 4798 times)
« on: May 12, 2014, 04:14:28 pm »
I have been doing logs for some time on my car and the highest MAF reading I get through the G70 sensor is 364.08g/s and it will not go any higher.
As this looks to be a limitation of the sensor, does it mean it will affect correct air/fuel ratio higher up the rev range?
Re: What is the maximum MAF reading?
« Reply #1 on: May 13, 2014, 12:23:23 pm »
The answer to this is YES.
364.08g/s is the highest reading that the MAF sensor can read on the TFSi - this is true of the MKV Golf too.
This doesn't mean that this is the power limit, it just means above this the ECU adapts.
MAFless mapping is a possible option .
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #2 on: May 13, 2014, 12:29:43 pm »
Can you use the MAP sensor for mapping?
I remember the Civic Type-R tuners used the MAP sensor for mapping for any forced induction tuning as the OEM MAF wasnt up to the job once you add boost
« Reply #3 on: May 13, 2014, 12:39:27 pm »
Off hand I don't know......**goes off to look** :happy2:
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #4 on: May 13, 2014, 12:40:37 pm »
TDI North in Warrington - Paul West is the guy that specialises in VTEC tuning
Offline Pikey Motorsports
« Reply #5 on: May 13, 2014, 12:51:13 pm »
Mafless would be cool
TSR PERFORMANCE GTX30 520BHP
LITCHFIELD R35 GT-R 660BHP
MSL E63 AMG 720BHP
HCP BM3 M5 800BHP
Offline Shorty
  • -Receive: 24
« Reply #6 on: May 13, 2014, 12:55:48 pm »
I'm pretty sure you can tune off the MAP, I've seen it done on diesels loads.
I didn't know about the MAF limit, random! You could always scale the MAF differently too could you?
| Mk7 R |
« Reply #7 on: May 13, 2014, 03:27:05 pm »
John if you kept your car stock you wouldn't have this issue...  :evilgrin:  :laugh:
« Reply #8 on: May 13, 2014, 04:12:52 pm »
Did you just say the S word :sick: :confused:
MSL E63 AMG 720BHP
HCP BM3 M5 800BHP
Offline xjay1337
  • -Receive: 377
« Reply #9 on: May 13, 2014, 04:17:37 pm »
Yup I had a Mafless code on my TDI.
It's not ideal, you'd want it done on MAF if possible. MAP has it's own benefits and drawbags normally extra lag. as it fuels based on boost which obviously takes longer to build if there's not as much fuel available..
« Reply #10 on: May 13, 2014, 04:31:09 pm »
Now you know that would be no fun at all.  :laugh:
Offline Shorty
  • -Receive: 24
« Reply #11 on: May 13, 2014, 04:32:17 pm »
My best mate has got a 330D on a MAF'less tune and it drives awesome, running 400bhp 700lb/ft.
| Mk7 R |
Offline Shaw
« Reply #12 on: May 13, 2014, 04:47:43 pm »
Possible to get a larger maf housing and adjust fuelling/maf maps to accommodate?
'07 Mk5 GTI Manual
« Reply #13 on: May 13, 2014, 05:08:01 pm »
Already on a larger MAF housing and fuelling already adjusted. 364g/s is actually around 400g/s on mine and still maxed out!.   :rolleye:
Offline xjay1337
  • -Receive: 377
« Reply #14 on: May 13, 2014, 05:11:32 pm »
Impressive.
Hardware mods?
