Author Topic: Problem with boost gauge pod fitment  (Read 816 times)
Offline Syrag64
« on: May 12, 2014, 06:55:16 pm »
I purchased 1 of the mk5 in front of dials pods and gauge from awesome but whilst fitting the pod it seems to be too big and is touching the front of the oem dial surround, has anyone else had problems fitting these pods?
Black 2007 GTI Manual, Stage 3 K04, R32 Bumper/Exhaust, WALK, adj rear ARB, KW1's, Twintercooler, Twintake, 18's (winters), 19's (summer) modified dectane LED rear lights, NQSBBK, Forge dump valve, Xenon look headlights with 5000k HID, 3" downpipe with sports cat, TT wishbones, uprated HPFP, Sach Uprated Clutch, Quaife LSD, VT & THS Engine Mounts.
To be fitted: Reverse Camera & uprated headunit.
Future plans: De-dent & Detail
Offline Syrag64
Re: Problem with boost gauge pod fitment
« Reply #1 on: May 13, 2014, 03:33:33 pm »
Anyone??
This is the item i am having trouble with
http://www.awesomegti.com/car/vw/golfmk5/newsouth-mk5-golf-offset-column-pod  :fighting:
Offline xjay1337
  • -Receive: 377
« Reply #2 on: May 13, 2014, 04:16:28 pm »
Pull the steering out slightly.
Offline Syrag64
« Reply #3 on: May 14, 2014, 05:00:54 pm »
 :ashamed: How do I do that?
Offline SurreyED30
« Reply #4 on: May 14, 2014, 06:04:36 pm »
Underneath the steering wheel is the column adjustment leaver which allows you to lift/lower the height if the steering wheel and also pull it more towards you or closer to the dials.
pull it down and pull the steering wheel forward, the pod will now fit. push the leaver back in and your done  :happy2: just abit of advice, rub down the pod where it meets the steering wheel as it may rub which will drive you insane   :laugh:
« Last Edit: May 14, 2014, 06:25:16 pm by SurreyED30 »
Offline Syrag64
« Reply #5 on: May 14, 2014, 07:05:15 pm »
Cheers :happy2:
Offline SurreyED30
« Reply #6 on: May 14, 2014, 07:44:06 pm »
No worries mate any time  :happy2:
