Author Topic: How to remove boot lid inside trim help  (Read 6774 times)
Offline N44LED
« on: May 14, 2014, 06:24:30 pm »
Hi guys any idea on how the trim on the inside of the boot lid comes off.
Aled
Offline mb
  • -Receive: 29
Re: How to remove boot lid inside trim help
« Reply #1 on: May 14, 2014, 06:52:49 pm »
There's a screw in each handle that you need to remove and there are clips around the edges and a couple in the middle. You can free some of the clips with trim removal tools by poking them inbetween the trim and bodywork. You need to use a bit of brute force to get the panel off still
Offline doylebros
Offline andybon
« Reply #3 on: May 14, 2014, 07:31:38 pm »
Don't just yank it off, I ended up smashing it into 4 pieces. They are £120 new from the delalers too :/
How hard can it be?
Offline daedos
« Reply #4 on: May 14, 2014, 09:01:56 pm »
Bit of a pig. Pull needs to be even and not just forced from bottom - tends to bend the locating pegs and cause the metal brackets to misalign. Doh.
Do you need to remove the trim?
Offline stuart-88
  • -Receive: 21
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,101197.0.html
« Reply #5 on: May 14, 2014, 09:43:20 pm »
Brute force and ignorance! Mine landed about 5 foot from my car when I first had to remove it.
Instagram: stu_nc88
Offline J12spk
  • VW PERVERT
« Reply #6 on: May 14, 2014, 10:18:34 pm »
I just actual lolled at this! My mrs wondered what was so funny, when I told her she called me a cock! Weirdo!
Das Auto
Offline N44LED
« Reply #7 on: May 15, 2014, 08:04:44 am »
Cheers guys couldn't see them screws. Was bugging me as I saw me arse and left it for an hour before I bork it.
Need to get it off for the dab amp in the back screen and possibly the reversing camera
Offline !tf
« Reply #8 on: May 15, 2014, 08:39:21 am »
Just rag it pal. Worked for me.  :grin:
2005 Tornado Red GTI. Pescaras, Eibach Sportlines, Kenwood DDX-4028bt, Galactic Empire tax disc holder.
"It never got weird enough for me."
Offline DDM
« Reply #9 on: May 15, 2014, 08:44:07 am »
i usually use a trim removal tool bud, but run a piece of masking tape or a cloth along the paintwork side firstly so not to scratch it, as said though they're a pig, you'll be lucky not to break some of the clips.
« Reply #10 on: May 15, 2014, 12:43:06 pm »
There's a reverse camera fitting guide on here that I believe covers the removal of the boot trim.
Offline Deago
« Reply #11 on: May 15, 2014, 02:12:09 pm »
Just yank at it obnoxiously send the clips flying everywhere and bending the plastic guides and spend half an hour putting all the bits back together  :evilgrin:
But seriously, when i did my rear lights it was bitterly cold, brittle plastic and hurting hands. So you'll probably have more luck than my first time round with the current weather! Dont go at it with a feather duster, i thought i'd done something wrong or not unscrewed something, i was just being too shy with it
Offline andybon
« Reply #12 on: May 17, 2014, 05:49:36 pm »
You think removal is bad, Re fitting involves broken wrists, loads of banging, and madness as when you finally get it back on one of the clips falls off and ends up inside the bootlid rattling about!
How hard can it be?
Offline sootpig
« Reply #13 on: May 17, 2014, 06:40:43 pm »
Bloody hell cant believe its been so much trouble for some  I removed mine without any trouble No broken clips or plastic cover Good set of plastic trim tools and knowing where the clips are helps a lot
