Author Topic: Air Con Top Up  (Read 1865 times)
Offline SeaV
Air Con Top Up
« on: May 16, 2014, 02:59:24 pm »
Getting my aircon topped up today at ATS for £33 including clean - checkout AmazonLocal for a current voucher offer giving you £22 off ATS price. Really easy, pay on your amazon account, take voucher code to ATS - sorted!
Sent from my iPhone
Offline lordbigsack
Re: Air Con Top Up
« Reply #1 on: May 16, 2014, 03:43:57 pm »
cheers,  Wife was only saying last night the aircon wasnt working.  Dont know much about aircon recharging though, is this a good price for it?
Standard Edition 30
Offline kris
Re: Air Con Top Up
« Reply #2 on: May 16, 2014, 05:00:21 pm »
Damn! Had mine done a couple of weeks ago but paid £49.
To everyone else - snap this up now! Good price.
Offline J400uk
  • -Receive: 27
Re: Air Con Top Up
« Reply #3 on: May 16, 2014, 05:58:10 pm »
Yeah that's very cheap for sure
Offline Ranbeer Singh
Re: Air Con Top Up
« Reply #4 on: May 16, 2014, 06:00:51 pm »
Got mine done from ATS a couple of days ago.
Good stuff  :happy2:
Rick
Offline chris-182
Re: Air Con Top Up
« Reply #5 on: May 16, 2014, 09:21:34 pm »
cheers! mine is desperate for a re gas :)
Offline skard
  • -Receive: 245
Re: Air Con Top Up
« Reply #6 on: May 16, 2014, 10:11:37 pm »
Thanks for the headsup
Offline gazrn
Re: Air Con Top Up
« Reply #7 on: May 16, 2014, 11:26:03 pm »
Just bought my voucher, cheers pal  :happy2:
Offline SeaV
Re: Air Con Top Up
« Reply #8 on: May 17, 2014, 07:53:38 am »
ATS were easy - it did take one and half hours because it had completely run out, but the temp test when I went in was 30.7degC and 11.2degC after they had done it. They said if I used it for a few days it would get even cooler, and should go down to 4deg!  Very pleased with their work and appears to be good value too :)
Offline lordbigsack
Re: Air Con Top Up
« Reply #9 on: May 18, 2014, 11:15:35 am »
Gas was completely empty according to ats.  However, after the regas the aircon still doesn't work.  Guy reckoned it was either the power or compressor fault.    Ran a scan and no errors came up, anyone got any ideas?
Standard Edition 30
Offline Baz300
Re: Air Con Top Up
« Reply #10 on: May 18, 2014, 11:22:11 am »
VCDS or generic code reader scan?
Offline lordbigsack
Re: Air Con Top Up
« Reply #11 on: May 18, 2014, 11:55:02 am »
Scanned using torque. Don't have vccds.
Just searched the forum (I know, should looked first) and found a couple of threads about compressors dieting prematurely.  Not sure how long the aircon has been off as I haven't had the car very long and this Is the first bit of good weather to test it.
Standard Edition 30
Offline skard
  • -Receive: 245
Re: Air Con Top Up
« Reply #12 on: May 18, 2014, 12:01:46 pm »
VCDS can tell you the status of the aircon, as in it will say exactly what is the cause for it failing to activate. You need to be in measuring blocks as it may not come up as a logged fault. Try get someone local to you to do this before looking at replacing bits.
My aircon stopped in my last car when I swapped the ECON switch type panel for an AC panel, I doubt this is your reason but it is not always the compressor.
Offline J400uk
  • -Receive: 27
Re: Air Con Top Up
« Reply #13 on: May 18, 2014, 01:35:37 pm »
Sounds exactly the same as what happened to me last month. Mine turned out to need a new compressor  :sad1:
As above try the VCDS measuring blocks and look to see what the Compressor Shut Off code is. It could just be that the pressure switch is dead which is what tells the car whether or not it has enough gas (I changed this also).
Offline golfgti10
Re: Air Con Top Up
« Reply #14 on: May 18, 2014, 11:04:05 pm »
A bit off topic but is there any air con top up etc available to come to your front door and do it outside
