Author Topic: VW Touch/Bury Bluetooth kit with MFD2 and CD Changer?  (Read 1534 times)
Offline DaneJD
« on: May 16, 2014, 05:54:27 pm »
Hopefully somebody may be able to shed some light on this, I am hoping to fit a VW Touch bluetooth kit or Bury bluetooth kit as some may know them to my 2005 GTI with factory MFD2 nav and CD changer.
My question is will I lose the CD changer function by fitting this? It's been removed from a 2010 Passat and uses the quad lock wiring harness system which I believe is compatible I just don't want to lose any of the standard functionality.
Thanks guys.
Offline J400uk
  • -Receive: 27
Re: VW Touch/Bury Bluetooth kit with MFD2 and CD Changer?
« Reply #1 on: May 16, 2014, 09:18:01 pm »
Shouldn't affect the CD Changer as it's a different connection. You might need to adjust a couple of the pins though if it's from a 2010 as the Bluetooth pin in the quadlock changed in newer models.
Offline DaneJD
« Reply #2 on: July 13, 2014, 12:12:15 pm »
Thanks for the help
