Author Topic: Aux compatibility with rcd300  (Read 18209 times)
Offline sam25man
« on: May 18, 2014, 12:29:38 am »
Hi everyone
I have this item:
http://www.ebay.co.uk/itm/190859587792
 was wondering wether it will fit a RCD300 stereo
Also wether I would need a adaptor
Any suggestions would be greatly appreciated
Offline CarlW
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,92229.msg927100.html#msg927100
Re: Aux compatibility with rcd300
« Reply #1 on: May 18, 2014, 03:12:50 am »
The white connector at the end of that item in the link goes straight into the back of the RCD300 where you'll find the majority of wires leading to not sure on what its actually called but you'll know what i mean when you pull the RCD300 out.
My iPhone/iPod kit works in exactly the same way except i had to connect the earth from iPod setup to the earth of the bunch of wires mentioned above.
You shouldn't need to do this i don;t think and you shouldn't need any adaptors i am aware of just 'Plug and play'
Offline sam25man
« Reply #2 on: May 18, 2014, 12:49:33 pm »
i just got it fitted at a car audio shop near to my house, and they have fitted but have said the part doesn't work
so its all set up but doesn't work :(
Offline CarlW
« Reply #3 on: May 18, 2014, 02:08:52 pm »
tried pressing the 'CD' button twice?
Offline DamoP
  • -Receive: 115
  • 2007 Edition 30 number 1242
« Reply #4 on: May 18, 2014, 02:41:49 pm »
Hi everyone
I have this item:
I'm selling one in the for sale section that will work in your head unit
MDI Armrest & Glovebox kits
Armrests, cloth and leather
Offline J400uk
  • -Receive: 27
« Reply #5 on: May 18, 2014, 02:46:11 pm »
Only the newer RCD 300 supports AUX Input, identified by the silver buttons. Fitted for MY2007 onwards
Offline SurreyED30
« Reply #6 on: May 18, 2014, 02:47:26 pm »
demon666's kit is very easy to fit and works spot on  :happy2: fitting time in less than 15 minutes
Offline DamoP
  • -Receive: 115
« Reply #7 on: May 18, 2014, 02:58:49 pm »
cheers dude  :happy2:
Offline SurreyED30
« Reply #8 on: May 18, 2014, 03:01:16 pm »
No worries mate, wanted aux for a while but was put off by reading threads on  a few forums saying ' you need this loom and these connectors plus coding blah blah  :rolleye: ' where as yours is straight plug and play no hassle for under £28! Bargain if you ask me
Offline DamoP
  • -Receive: 115
« Reply #9 on: May 18, 2014, 03:06:15 pm »
 :happy2: :happy2: :happy2: :happy2: :happy2:
Offline sam25man
« Reply #10 on: May 18, 2014, 05:46:02 pm »
Tried that does not work
Offline sam25man
« Reply #11 on: May 18, 2014, 05:48:20 pm »
Hi everyone
I have this item:
Do you have a link for it? how much ? thanks
Offline sam25man
« Reply #12 on: May 18, 2014, 05:48:47 pm »
Mine is the older version which is all black
Offline J400uk
  • -Receive: 27
« Reply #13 on: May 18, 2014, 07:41:51 pm »
Yeah in that case it's unlikely the VW cable will work
Offline DamoP
  • -Receive: 115
« Reply #14 on: May 18, 2014, 07:47:15 pm »
I can do a pin swap so my aux kits work  :happy2:
