Author Topic: K04.............at last.  (Read 9121 times)
Offline SurreyED30
Re: K04.............at last.
« Reply #15 on: May 24, 2014, 09:13:37 am »
What setting are you using at the mo?
Offline pitsirikas
  • -Given: 19
« Reply #16 on: May 24, 2014, 10:23:44 am »
B9/T6/F9 at the moment but I'm sure I'll turn it down at the end.
                     Don't drive faster than your angel can fly..!
                Respect a man's car and the man will respect you
Offline SurreyED30
« Reply #17 on: May 24, 2014, 03:31:54 pm »
Yeah I turned mine Dow. when I fitted the s3 cooler because didn't want the hoses popping off during the test drive lol will crank it up again when stage 2+ happens  :evilgrin:
Offline pitsirikas
  • -Given: 19
« Reply #18 on: May 25, 2014, 08:57:38 am »
In the SPS User Guide these are the adjustments given by Revo...
Boost Adjustments:
Range 0 Valet Mode
Range 1 Stock Boost
Range 6 Performance Boost
Range 9 Aggressive Boost
Timing Adjustment:
Range 0-3 91(US)/95(Euro) Octane Fuel
Range 4-6 93(US)/98(Euro) Octane Fuel
Range 7-9 Unleaded Race Fuel over 100 Octane
Fuel Adjustment:
Range 0 Stock Air-Fuel Ratio (AFR)
Range 9 Performance Air-Fuel Ratio (AFR)
so..........
B9/T6/F9 all the away
I think most richen the fuel by running F7 or F6.
You are right.
..........maybe we are both wrong bacillus... :confused:
« Last Edit: May 25, 2014, 09:31:40 am by pitsirikas »
« Reply #19 on: May 25, 2014, 09:35:50 am »
Nah, even revo themselves set up their stage 2+ cars using F6.
Offline pitsirikas
  • -Given: 19
« Reply #20 on: May 25, 2014, 10:04:15 am »
Here in Greece most (if not all) Stage 2+ cars are F9.
I'll contact the official dealer tomorrow (because last night when I went for a fast drive I saw 2 bar - 29 psi  :scared: and I have to turn the boost down)
and we will have our answer for good.
Offline pitsirikas
  • -Given: 19
« Reply #21 on: May 26, 2014, 07:00:42 pm »
According to Revo - Greece F9 is the richest.
« Reply #22 on: May 26, 2014, 07:39:23 pm »
Actually F9 is the leanest setting and any setting less than 9 i.e. F6 or F7 richens up the fuelling.
Offline pitsirikas
  • -Given: 19
« Reply #23 on: June 19, 2014, 03:15:44 pm »
I misunderstood............... :ashamed:
bacillus is correct.................F9 is the leanest
Offline GarethB
« Reply #24 on: June 20, 2014, 02:01:34 pm »
I'm Revo Stage 3 and (after lots of work & tweaks by Alex at AKS) am set up running B9 T7 F9, and she feels strong.
As stated elsewhere, the settings seem to vary hugely between cars.
Hope you're enjoying Stage 3  :driver:
Offline pitsirikas
  • -Given: 19
« Reply #25 on: June 25, 2014, 11:01:10 am »
I also kept 969 and you are absolutely right.
She feels really strong.... :happy2:
Offline jasam
  • My Ride: 2.0 tfsi k04, revo stage 3
« Reply #26 on: October 05, 2016, 10:42:02 am »
this is old topic but still hot :)
did you log after putting those settings? car will feel.great, but it will not be great once you log lambda actual vs requested, lambda regulator, both boosts, maf g/s. you will have situation between 5000-6000rpm. i speaking on revo stage 3 map.
cannt speak generally for all cars, but few of them had same thing.   nothing bad will happen, but lambda actual cannt meet requested at that rev range, and few other things.. and I preefer to have all parameters spot on
« Last Edit: October 05, 2016, 10:49:00 am by jasam »
