Author Topic: Front speaker rattle  (Read 3372 times)
Offline Mullan
« on: May 18, 2014, 05:39:54 pm »
Hi,
I've got a rattle coming from my passenger side bottom speaker when bass is on. I've taken the door card off and noticed vw were kind enough to rivet the speakers in so before I drill them out I just wanted to know if anyone has this problem and solutions?
I'm hoping it might be the speaker wire to the cone is touching the cone when it vibrates or whether the speaker is blown and I require a new one?
Thanks.
Offline Shaw
Re: Front speaker rattle
« Reply #1 on: May 18, 2014, 07:18:17 pm »
I had a rattle when the bass was really pumping. Turned out to be one of the door skin inner bolts was loose.
'07 Mk5 GTI Manual
Offline Mullan
« Reply #2 on: May 18, 2014, 07:19:04 pm »
Is the skin hard to remove, I've seen the torx bolts but not sure how it's on at the top?
Offline Wooosh
  • -Receive: 87
  • Factory ponies.
« Reply #3 on: May 20, 2014, 12:32:46 am »
To tighten up the torx bolts you don't need to remove the door skin.
Stage 2 MK5 GTI Revo GONE
Stage 1+ MK5 GTI R-Tech GONE
Offline xjay1337
  • -Receive: 377
« Reply #4 on: May 20, 2014, 01:23:29 am »
you'll probably find its the larger speaker grill mesh if you put your hand on it, it will stop.
sound deadening material will stop it.
Offline Mullan
« Reply #5 on: May 20, 2014, 09:55:25 am »
I was considering getting access behind the speaker and potentially sound deadening the door skin
