Author Topic: Antifreeze/Coolant  (Read 3114 times)
Offline prp74
  • -Receive: 126
Antifreeze/Coolant
« on: May 18, 2014, 06:04:38 pm »
Guys,
Just need to top up my antifreeze/Coolant. Did a quick search and still a bit confused.
I have used the ready mix halfords before and seemed ok.
Would this is be ok?
http://www.eurocarparts.com/mobile/ecp/c/Volkswagen_Golf_2.0_2006/p/car-parts/car-lubricants-and-car-fluids/lubricant-and-fluids/anti-freeze2/?523770511&1&ca1fce5141308ce451c0eccdb1f96ae038c51a99&000397
Or any other recommendations with links please.
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
Re: Antifreeze/Coolant
« Reply #1 on: May 18, 2014, 06:55:26 pm »
VW G12 coolant is what is in it and it's also the best stuff. Pick up a litre from your local dealer would be my advice  :happy2:
Offline MJ
« Reply #2 on: May 18, 2014, 07:08:54 pm »
Now it's G13 :)
2005 VW Bora TDI 130 Highline auto. Current mods: 5.5lt washer bottle & black and aluminium A/C knobs & 312mm front brakes and 256mm vented rear brakes.
Next: turborevs SMIC, 20vt pancake pipe and silicone connectors.
VCDS, ODIS, VAS - PC and multi brand diagnostics around Manchester - pm me for help and advice
Offline prp74
  • -Receive: 126
« Reply #3 on: May 18, 2014, 08:03:05 pm »
Thanks guys
Offline gti265
« Reply #4 on: May 19, 2014, 12:05:05 am »
Just go in and say you want to buy some to do a small top up, most will just top you up with there workshop bottle had it done at vw and audi now on diffrent cars
Tom
MK6 Golf R DSG 2012 - FOR SALE - £20,000 - pm for info
Offline Wooosh
  • -Receive: 87
  • Factory ponies.
« Reply #5 on: May 19, 2014, 01:49:20 am »
G13 coolant additive provides the same exceptional cooling and antifreeze performance as G12++, but is manufactured in an environmentally sustainable way, using glycerin instead of glycol. Glycerin, a bi-product of biodiesel production, is much less harmful to the environment than glycol-based products, which are produced from mineral oil. In comparison with the manufacture of traditional coolant additive, it is estimated that G13 production will produce 11 per cent lower CO2 emissions. So G13 is the coolant you want. :happy2:
Stage 2 MK5 GTI Revo GONE
Stage 1+ MK5 GTI R-Tech GONE
Offline OSB
  • -Given: 32
« Reply #6 on: May 19, 2014, 05:31:17 pm »
That's interesting ! And lot more use than my local stealer when I asked what the difference was, said 'G13 is newer and better .......' :confused:
But are they fully interchangeable/ mixable? Or do you need to drain, flush and refill.
Offline Wooosh
  • -Receive: 87
  • Factory ponies.
« Reply #7 on: May 19, 2014, 11:38:46 pm »
Sounds like your local stealers is very ermmm helpful? :confused: I drained, flushed & refilled mine for piece of mind.
