Author Topic: help with upgrading to highline clocks  (Read 1352 times)
Offline usmangti
« on: May 19, 2014, 09:30:48 pm »
So I currently have mid line 960D clocks. Can anyone help and advise me if 972D clocks will fit and code correctly?
Any help appreciated!
Usman
« Last Edit: May 19, 2014, 09:35:59 pm by usmangti »
Offline scooba
  • -Given: 18
Re: help with upgrading to highline clocks
« Reply #1 on: May 19, 2014, 10:06:13 pm »
Speak with eddie-nl
Offline sanj
  • -Given: 17
« Reply #2 on: May 19, 2014, 11:35:19 pm »
As scooba say's it's Eddie or Kalu that can do it,you won't find anybody close that can(tried local specialist in Huddersfield when I had my Edition30)good luck with your search. :happy2:
Offline Wooosh
  • -Receive: 87
  • Factory ponies.
« Reply #3 on: May 19, 2014, 11:46:13 pm »
Highline clocks can be coded and fit as good as your current clocks, just get in contact with Eddie-nl hes the man you wanna talk to.
Stage 2 MK5 GTI Revo GONE
Stage 1+ MK5 GTI R-Tech GONE
Offline usmangti
« Reply #4 on: May 20, 2014, 12:00:48 am »
Thanks guys Eddie has said they should work fine!
Sanj just out of interest, which specialist you referring to?
Eddie and kalu are just too far to visit, I assume they need the car present to code the clocks.
Offline Wooosh
  • -Receive: 87
  • Factory ponies.
« Reply #5 on: May 20, 2014, 12:05:05 am »
Just to confirm the car does need to be present to code the clocks.
Offline usmangti
« Reply #6 on: May 20, 2014, 12:12:49 am »
Thanks bro :happy2:
Offline Wooosh
  • -Receive: 87
  • Factory ponies.
« Reply #7 on: May 20, 2014, 12:29:41 am »
Thanks bro :happy2:
Happy to help mate. :drinking:
Offline skard
  • -Receive: 245
« Reply #8 on: May 20, 2014, 06:42:39 am »
Both those clusters can be DIY'd, if travelling to Eddie or Kalu is too far.
Offline Greigzy
« Reply #9 on: May 20, 2014, 02:35:59 pm »
If the 972 clocks dont work with your existing clocks, I have a set of 970 Highline ones for sale
Offline sanj
  • -Given: 17
« Reply #10 on: May 20, 2014, 02:58:48 pm »
The specialist is VAST on Manchester Road.
Offline mvb12
  • -Receive: 64
« Reply #11 on: May 20, 2014, 07:57:40 pm »
Thanks bro :happy2:
The car does not need to be present to code them.
You can send the clocks to Eddie or Kalu to sort the mileage ect out.
Offline usmangti
« Reply #12 on: May 20, 2014, 08:57:46 pm »
@sanj
Never used VAST but reaper7881 knows someone around town for immobiliser coding and pin extraction.
Thanks bro :happy2:
Confused by all this. I was under impression for immobiliser etc and coding car needs to be present?
Ive asked Eddie-NL so will let update this when I hear back
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
« Reply #13 on: May 20, 2014, 09:03:30 pm »
Thanks bro :happy2:
^^^ This
I sent my clocks from Ireland to Kalu and had them back within three days, all sorted
Offline skard
  • -Receive: 245
« Reply #14 on: May 20, 2014, 09:08:39 pm »
You can remove your clocks and send both sets to either Eddie or Kalu. Or..
You can drive to either Eddie or Kalu and have it done in situ, or anyone local. Or..
You can use an unofficial cable on both of your particular (early mk5) clusters and DIY fit them with immo and mileage correction.
