Author Topic: Ed 30 High revs at start up?  (Read 1581 times)
Offline galaxie500
  • -Given: 38
  • 56 plate 5 door in Black Pearl Metallic
« on: May 20, 2014, 08:01:43 am »
My 75K mile Ed 30 is often exhibiting very high revs on & after start up which then settles back down to normal idle shortly afterwards. This seems to happen usually when the car is warm but it has occurred cold too. What should I check gents? It had a PCV last year and pretty sure the DV good. Is it a fuelling problem?
Thanks.
PR
Offline mvb12
  • -Receive: 64
Re: Ed 30 High revs at start up?
« Reply #1 on: May 20, 2014, 08:24:03 am »
Thanks.
PR
mine normally kicks off to around 1100/1200 on cold start and settles to around 800.
this is normal unless your revs are severely higher?
Offline galaxie500
  • -Given: 38
« Reply #2 on: May 20, 2014, 11:16:30 am »
Thanks for your reply.  Annoyingly the revs shoot up to 2500 revs, which can't be good on a warm engine let alone one starting from cold.
Any other ideas?!
PR
thomga01
« Reply #3 on: April 17, 2015, 07:27:59 pm »
My GTi is doing exactly the same - did you get to the bottom of this?
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #4 on: April 17, 2015, 09:19:42 pm »
Coolant temp sensor? Had those exact symptoms (albeit on a PD) so maybe it's a starting point.
Of course a better starting point would be a diagnostic scan, but you know that ;-)
Offline AJP
  • -Given: 392
  • -Receive: 316
« Reply #5 on: April 17, 2015, 09:20:19 pm »
Old thread resurrection fail
thomga01
« Reply #6 on: April 18, 2015, 01:18:36 pm »
Thanks for tip. Garage has done the scan - nothing reported. I will change the coolant sensor to see if it fixes it.
