Author Topic: Hello all. Need help with my RNS510 firmware selection.  (Read 4984 times)
Offline ad_182_uk
Re: Hello all. Need help with my RNS510 firmware selection.
« Reply #15 on: May 20, 2014, 09:48:54 pm »
Will this work for example?
Althpugh still unsure about SD card compatability... I could use usb but it seems horrifically slow, my current one tales 5mins before it registers then if i want to cycle folders it will just freeze for 2-3 mins before sorting itself out.
Might be as its an old usb or might be that its going through the MDI???
Did you miss something out here?
Yes! Lol
This link ok for the 3810 firmware?
http://www.rnsfirmware.com/rns510-firmware-for-a-and-b-units-3810a/
So being 'hw03' wont cause issues with using 32GB?
Offline Viking
  • -Given: 17
  • -Receive: 47
« Reply #16 on: May 20, 2014, 09:59:46 pm »
That should be fine, although I've never downloaded a firmware from their links, I would think it'll be okay.
Sarcasm for free. Anything after that can only be considered as a bonus.
Just because you think you know something, doesn't make you an expert if you've just read it on the internet, y'know.
Offline ad_182_uk
« Reply #17 on: May 20, 2014, 10:02:22 pm »
Yes! Lol
Just tried and its just an ISO file so i guess not as it should be .nrg?
Offline Viking
  • -Given: 17
  • -Receive: 47
« Reply #18 on: May 20, 2014, 10:15:44 pm »
An ISO file needs to be burned to disc using a specific program such as magic ISO, Power ISO, or IMGBurn. ISO is the correct format for a firmware update disc to be made.
Offline ad_182_uk
« Reply #19 on: May 20, 2014, 10:30:57 pm »
I found this...
www.mk5gfgti.co.uk/forum/index.php?topic=23779.0
Then i have started the download for '381X firware (latest for all a/b/c units)
So hopefully that one works. Then will do vuci downgrade disc, then maps if required. Then sd card with speed cam POI's.
Then hopefully a 32gb sd card will work too and everything will be hunky dory fingers crossed...
Offline ad_182_uk
« Reply #20 on: May 20, 2014, 11:44:04 pm »
Just tried this bug i dint get a .nrg file after extracting like it says i should :(
Does anyone have the 3810 firmware .nrg file they can email or link me? Or will the iso file work once burned to disc?
Adam.
Offline Viking
  • -Given: 17
  • -Receive: 47
« Reply #21 on: May 21, 2014, 06:11:08 am »
Just burn the iso file to disc with imgburn
Offline ad_182_uk
« Reply #22 on: May 21, 2014, 02:10:52 pm »
Will goin to fw3810 stop my kufatec bluetooth / nav showing up on mfd / steering wheel controls from working?
Offline Viking
  • -Given: 17
  • -Receive: 47
« Reply #23 on: May 21, 2014, 03:48:38 pm »
Might need to re enable them with VCDS.
Offline ad_182_uk
« Reply #24 on: May 21, 2014, 04:58:01 pm »
:/ havent got a copy. Anyone on here near long eaton, nottingham?
Offline ad_182_uk
« Reply #25 on: May 21, 2014, 09:07:55 pm »
Ok it went on and everything still works fine.
So i tried to put a SD card in (2gb fujifilm) and it just threw up a sd card read error? Why wont the system read it when my pc read it fine?
Adam.
Offline Viking
  • -Given: 17
  • -Receive: 47
« Reply #26 on: May 21, 2014, 09:19:29 pm »
How have you formatted the SD card? It should be formatted FAT32.
Offline ad_182_uk
« Reply #27 on: May 21, 2014, 09:25:35 pm »
Yup did full format in fat32 ten added the .db3 file i think it is to a folder called personalpoi...
Button for import my poi's always remains faded on the unit atm.
Offline Viking
  • -Given: 17
  • -Receive: 47
« Reply #28 on: May 21, 2014, 09:39:45 pm »
Okay, have you loaded the firmware which has 3 partitions? Press and hold the "Setup" button for about 20 seconds and the unit should cycle through 2 menu screens before landing at the developers menu. Look for "HDD Status" and select, then check for "Partitions" and make sure there are three available. If so, then you have the partition for the PersonalPOI (note the exact spelling and capitalisation there).
If the DB3 file is called PersonalPOI, and is in a folder called PersonalPOI, and you have three partitions, then you could have a hardware issue.
Load an MP3 onto the SD card and see if you can play it.
Offline ad_182_uk
« Reply #29 on: May 21, 2014, 11:22:40 pm »
Oki doki will check for partitions in the morning. Should be 3 though as used fw3810. Will fond out for defo 2moro!
