Author Topic: Engine Error Light - 'Efficiency Below Threshold'  (Read 2981 times)
Offline Kalpsn2000
  • -Receive: 56
« on: May 21, 2014, 10:32:08 am »
Hi guys
Not been on here for a while but need some advice. A couple of weeks ago the engine light came on...only just round to scanning it and the following error came up (still there after clearing).
Address 01: Engine        Labels: 06F-907-115-AXX.lbl
   Part No SW: 1K0 907 115 J    HW: 8P0 907 115 B
   Component: 2.0l R4/4V TFSI     0030
   Revision: 5BH16---    Serial number:
   Coding: 040300031C070160
   Shop #: WSC 08708 803 00000
   VCID: 2D5735ABB4B420760F5-8078
1 Fault Found:
001056 - Catalyst System; Bank 1
               P0420 - 002 - Efficiency Below Threshold - MIL ON
             Freeze Frame:
                    Fault Status: 11100010
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 57355 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 08:09:16
             Freeze Frame:
                    RPM: 2354 /min
                    Load: 26.7 %
                    Speed: 95.0 km/h
                    Temperature: 85.0°C
                    Temperature: 9.0°C
                    Absolute Pres.: 1020.0 mbar
                    Voltage: 14.605 V
I've seen the Ross Tech page:
http://wiki.ross-tech.com/wiki/index.php/16804/P0420/001056
I've had a quick look around the engine bay...but not being an expert couldn't see anything obviously wrong.
Any advice as to what is the best thing to do or check?
Re: Engine Error Light - 'Efficiency Below Threshold'
« Reply #1 on: May 21, 2014, 03:03:38 pm »
If all looks ok under the bonnet then I would check for a faulty lambda sensor or an issue with your cat.
Are you mapped with stage 2 or above?
You can check your sensor by going into the engine module>basic settings and choose oxygen sensor aging test bank1. If you are not mapped or stage one, do bank 2 as well.
Offline Kalpsn2000
  • -Receive: 56
« Reply #2 on: May 21, 2014, 04:01:26 pm »
I'm only mapped to stage 1.
Ok will try the that in VCDS. Does it come back with a pass or fail?
Offline clemo
« Reply #3 on: August 13, 2015, 08:36:22 am »
Hi Did this get sorted ,  I have just fitter  a 200cel sports down pipe with cat to stock rear,  the other day i had the MIL light , can i sort this in VCDS
Offline Flyingscotsman
« Reply #4 on: August 13, 2015, 09:09:47 am »
You can reset the MIL light using VCDS but if the resaon it came on is that you have a de-cat or a sports cat fitted,  then it is likely to come back on again unless you get the lambda sensor mapped out or fit a lambda spacer.
