Author Topic: uprated ARB drop links - front and rear  (Read 9258 times)
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
Re: uprated ARB drop links - front and rear
« Reply #30 on: February 04, 2010, 09:57:42 pm »
whats the kuatec cable you spoke of ?
http://www.kufatec.de/shop/product_info.php/info/p1329_E-MFA-DIS-Add-On---Display-Boost--Oil--Battery.html
With Highline module you can get these infos in the screen in between rpm and speed, BUT not boost pressure for the 2,0 TFSI  :sad1:
Over the top mod list ;o)
Offline gillm
« Reply #31 on: February 04, 2010, 10:01:54 pm »
does it only work on highline mfa ? mine is a std mfa . it says nothing about highline required
west tuned gt28 @ 340hp
Offline Poppa Dom
« Reply #32 on: February 04, 2010, 10:05:12 pm »
Pretty sure this is highline only - boost only available on diesels.
  • -Given: 243
  • -Receive: 154
« Reply #33 on: February 04, 2010, 10:08:46 pm »
quote from Kufatec:
The vehicle needs to be equipped with DIS+
DIS+ = Highline  :happy2:
I'm awaiting Bluetooth box, i hope it works with this  :confused: but i think not  :sad1:
Offline xxx_mojo_xxx
  • MUBster DUBster
« Reply #34 on: February 04, 2010, 10:28:48 pm »
Just remember, turbo boost pressure is not available from the canbus...so you won't get a reading on a GTi.
Otherwise, everything else works fine.
Offline gillm
« Reply #35 on: February 04, 2010, 10:29:56 pm »
so you defo need highline ?
  • -Given: 243
  • -Receive: 154
« Reply #36 on: February 04, 2010, 10:50:06 pm »
