Author Topic: fault code help  (Read 1072 times)
Offline Alasdair
fault code help
« on: May 23, 2014, 07:47:08 pm »
hi guys after some advise i am utterly stumped with the fault i have got.
Friday,23,May,2014,19:41:13:38514
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
                Address 01: Engine       Labels: 06F-907-115-AXX.lbl
Control Module Part Number: 1K0 907 115 L    HW: 8P0 907 115 B
  Component and/or Version: 2.0l R4/4V TFSI     0030
           Software Coding: 0403000318070060
            Work Shop Code: WSC 01279 785 00200
                      VCID: 2F6D037CBE8B3E6632D-807A
1 Fault Found:
001089 - EVAP Emission Control Sys
               P0441 - 002 - Incorrect Flow - Intermittent - MIL ON
             Freeze Frame:
                    Fault Status: 10100010
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 126261 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 08:24:47
             Freeze Frame:
                    RPM: 842 /min
                    Load: 15.7 %
                    Speed: 0.0 km/h
                    Temperature: 83.0°C
                    Temperature: 26.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 14.224 V
Readiness: 0000 0000
I have already replaced the N80 valve has anyone come across this and knows what to go for next. performace is ok, sometimes i can experiance a lumpy idle but i cant seem to pick anything up for it i have done a measured values test and i can't pin point the fault to anything. It can be intermitant as well so that doesnt help. If only i have guided fault finding to help me!
Re: fault code help
« Reply #1 on: May 23, 2014, 07:52:34 pm »
http://wiki.ross-tech.com/wiki/index.php/16825/P0441/001089
Is your petrol filler cap correctly tightened?
Offline Alasdair
Re: fault code help
« Reply #2 on: May 23, 2014, 08:31:32 pm »
Yeah always check before I might get a new one just incase, looking at the guided fault finding online this has been an issue from about 2 years, my next step was the purge canister but all the pipe work has been modified so that needs to be changed to and comes to over £130
