Author Topic: Anyone got a rns510 map disc with speed cam locations?  (Read 1550 times)
Offline ad_182_uk
Re: Anyone got a rns510 map disc with speed cam locations?
« Reply #15 on: May 25, 2014, 11:23:56 pm »
Bump. Still need v9 maps with speed cam and other poi on CD if anyone got one. Needs to work with fw3810.
Adam.
Offline Viking
  • -Given: 17
  • -Receive: 47
« Reply #16 on: May 26, 2014, 07:04:36 am »
Don't you want V10 maps? V9 are a few years old now.
Sarcasm for free. Anything after that can only be considered as a bonus.
Just because you think you know something, doesn't make you an expert if you've just read it on the internet, y'know.
Offline Chrismeardon
« Reply #17 on: May 26, 2014, 10:36:26 am »
mine thinks it's in germany half the time.... any ideas?
Offline Viking
  • -Given: 17
  • -Receive: 47
« Reply #18 on: May 26, 2014, 10:46:16 am »
Regensburg syndrome. Could be a firmware issue, if it's been updated. Or it might cure it if you do update the firmware/maps.
Basically, Regensburg is the default GPS position of the RNS unit, so any time it loses its memory or suchlike it defaults to Germany until it finds a valid GPS signal and recalculates. Try a new GPS antenna, or reposition the one you have, see how you get on with that. Also, when you have the unit pulled out make a note of the part number and suchlike on the top, as you could need it if you do have to update the firmware at a later date.
Offline ad_182_uk
« Reply #19 on: May 26, 2014, 12:39:04 pm »
I dont think anyone has done a v10 maps with speed cams loaded onto yet you see. So at least was gaurenteed to get full maps with all the stuff on this way.
Adam.
Offline Viking
  • -Given: 17
  • -Receive: 47
« Reply #20 on: May 26, 2014, 04:14:08 pm »
I have V9 maps, but not sure if the speed cams are on it. They'll be a good bit out of date as well though, so maybe not accurate.
Did you try an mp3 on the SD card reader yet?
Offline Viking
  • -Given: 17
  • -Receive: 47
« Reply #21 on: June 16, 2014, 12:55:19 pm »
Did you manage to get maps with speed cams on yet? I might have a solution....  :party:
