Author Topic: Changing lower arm bushes and arb dust covers  (Read 1518 times)
Offline Johnny_tro
« on: May 24, 2014, 09:17:14 pm »
Is this a fair easy and straight forward job? Unbolt the parts.....remove and insert new rubbers?
Offline DDM
Re: Changing lower arm bushes and arb dust covers
« Reply #1 on: May 25, 2014, 08:44:21 am »
if you mean console bushes, then they arn't hard to do but you can't just do them on the driveway, i just did mine and replaced them for audi tt ones, i cut the old ones off after removing the whole bottom arm, then pressed the new ones on, as i didn't want to distort them by hammering ect. once you've got the old one off, make sure the hex shaped end of the bottom arm is clean of corrosion and greased up ready for the new one to go on too.
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
Re:
« Reply #2 on: May 25, 2014, 09:38:33 am »
I bought the tt console bushes complete in the housing so no need to press them in / out.
I did mine on the drive and did need to remove the whole arm in order to get enough room to remove the bush.
Jas
VCDS (Preston, Lancashire)
Offline Johnny_tro
« Reply #3 on: May 25, 2014, 06:54:58 pm »
Told from my service that I need to look at changing front and rear bushes......also arb dust covers.
Got some uneven tyre wear on front and slight knocking noise.
Concerned these are pressed in soooo ard you need machine to remove them?
Should I just gets complete kit like this....? Or just get some std oem ones
http://www.ebay.co.uk/itm/VW-Golf-Mk5-GTI-R32-Powerflex-Front-Wishbone-Front-Rear-Bushes-PFF85-501-502-/121320327373?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item1c3f4148cd
Offline DDM
« Reply #4 on: May 25, 2014, 07:13:21 pm »
that kit is just bushes I think bud, so you'll still need the ally housing to mount them in, so yes you'll need a press. pm maxitrol, he has that kit, and he pressed the old ones out and new ones in.
Offline Johnny_tro
« Reply #5 on: May 25, 2014, 07:30:01 pm »
Housing? I thought they just sat in the arm?
Offline DDM
« Reply #6 on: May 25, 2014, 07:45:24 pm »
the console bushes are in a aluminium housing that's pressed onto the rear of the bottom arm. you can buy complete ones like I did with the audi tt ones, then just cut the old housing and bush off, then press your new one on, or you'll have to remove the housing and bush of the bottom arm, then press the old bush out them replace with the likes of the kit you showed a link too.
Offline Johnny_tro
« Reply #7 on: May 25, 2014, 08:05:00 pm »
Oooo sounds little out my comfort zone :sad1: think I need book this in the garage
Offline DDM
« Reply #8 on: May 25, 2014, 09:18:57 pm »
up to you mate, either way you'll need to get the tracking aligned afterwards anyway, so a trip to a garage will be needed.
Offline mrxbox360
  • My Ride: 2008 Golf Mk5 GT TDI Sport 5dr Reflex Silver Personal Enchanced
« Reply #9 on: May 26, 2014, 07:08:13 pm »
Hi all i need to replace mine soon did the tt bushes make much difference as i can't decide as tt bushes £25 from dark side or walk kit approx £150,the car won't be doing any track days just normal roads.
Offline DDM
« Reply #10 on: May 26, 2014, 09:04:58 pm »
my bushes were just standard so when replaced for the tt ones and a re-alignment there was a huge difference mate.
Offline mrxbox360
« Reply #11 on: May 26, 2014, 09:35:49 pm »
Cheers you have saved me loads :star: ill get a set ordered from dark side  :grin:
Offline DDM
« Reply #12 on: May 26, 2014, 10:07:29 pm »
Offline BarberVW
« Reply #13 on: May 27, 2014, 11:56:33 am »
Can anyone post the link to these TT bushes please?
Black 3 Door Manual | Bi-xenons | Winter pack | Luxury pack2 | Cruise control | Highline display | MFSW | 18" Monza 2's | Armrest | Glovebox MDI | Blue tint glass
Offline mrxbox360
