Author Topic: Rear washer hose part number?  (Read 1163 times)
Offline afterburner
« on: May 25, 2014, 10:40:06 am »
Hi
Could anyone tell me what the part number is for the short piece of hose/pipe that goes to the rear wiper motor?
I was returning the rear wiper delete back to oem & the small piece of hose us missing.
Cheers in advance
Its for a 2008 mk5 ed30 5 door
Offline doylebros
Re: Rear washer hose part number?
« Reply #1 on: May 25, 2014, 06:43:26 pm »
Hi
Cheers in advance
You should be able to Identify what item numbers you need from this:-
http://www.partscats.info/volkswagen/en/?i=cat_vag_models&brand=vw&number=1714&set=1731&ein=2008&f=625&hauptgr=1234567890&hg=9&grf=095525474&bf=95525&hgug=955&ug=55&parent_id=2870124
Assuming it's only item 17 - Hose modify to suit - 2D0 955 962 - £4:51 full retail inc vat
Offline afterburner
« Reply #2 on: May 25, 2014, 11:46:44 pm »
Cheers bud
Think i'll be needing 15,16,17 & 18.
Will take parts info into vw & get the bits hopefully
Thanks for the info
