Author Topic: PolarFIS (Advanced) : New Update v0.4.3 [26-05-2014]  (Read 630 times)
« on: May 26, 2014, 05:31:02 pm »
Added support for new generation of RNS315 and white dot clusters that causes BT menu not visible (NOTE: Only last generation has BT menu)
Added new parameters:
 - DPF calculated soot mass
 - DPF measured soot mass
 - Lambda adaptation at idle
 - Lambda adaptation partial
Added new configuration for Lambda reading.
For configure it, go to configuration menu, and then VISUALIZATION->SCREEN->ADVANCED->LAMBDA OPTIONS
 - Standard (As readed)
 - Air fuel ratio (AFR)
Added new configuration for Gallons type.
For configure it, go to configuration menu, and then VISUALIZATION->SCREEN->ADVANCED->GALLON TYPE
 - Gallons UK
 - Gallons US
Improved russian language on white dot clusters
New engine database, added some models and corrected some measuring channels
Improved steering wheel controls in addition with BT emulation for older steering wheel models
Improved BT emulation for red dot clusters
For install this update, please use ActiveX from our official web www.auto-polar.com (Update Zone)
