Author Topic: FIXED: Just take and burn it... after ive taken my mods off  (Read 6291 times)
Offline mtj2k
  • 1.4 TSi GT
Re: Just take and burn it... after ive taken my mods off
« Reply #15 on: May 28, 2014, 11:55:03 pm »
Didn't fit the new sparks yet - ECP recommended the wrong plugs so i have to go swap them tomorrow..  :fighting2:
Offline omeydz
  • -Receive: 50
« Reply #16 on: May 29, 2014, 09:00:05 am »
See if the spark plugs you remove are sooty from rich running and if so which ones.
Also a note on the fuel line pressure. When I changed the fuel filter on my mk6 there wasnt much pressure. I did however pull the fuel pump fuse and let the engine run and then cut out before I started work. Thats the recommended way afaik for fuel system work.
Recently back on the forum! Good to be back
Current Rides
Mazda RX8 231bhp ( very different little rocket lol!)
SOLD
2007 MK5 Golf 1.4 FSI
2007 Golf MK5 GTI DSG
2008 Audi A5 3.0TDI
Offline mtj2k
  • 1.4 TSi GT
« Reply #17 on: May 29, 2014, 11:40:37 am »
Does anyone have access to current ETKA? Just been reading on the web that VW have superceded the spark plug number for ones with a smaller gap (0.7 instead of the 0.8 stock)
If you do - my engine is a 1.4 TSI 140bhp 'BMY'
Offline omeydz
  • -Receive: 50
« Reply #18 on: May 29, 2014, 12:57:35 pm »
Best bet to call VW dealers and give your reg.
Current Rides
SOLD
2008 Audi A5 3.0TDI
Offline mtj2k
  • 1.4 TSi GT
« Reply #19 on: May 29, 2014, 01:16:53 pm »
Got some NGK PZFR6R's
Will fit tonight  :happy2:
anorganix
« Reply #20 on: May 29, 2014, 03:37:50 pm »
A little late, but just for reference - I was able to find 03C905601A for engine codes BLG & BMY.
However, it seems that there is a revised version which has PN 03C905601B.
Keep us updated.
« Last Edit: May 29, 2014, 03:40:15 pm by anorganix »
Offline mtj2k
  • 1.4 TSi GT
« Reply #21 on: May 29, 2014, 07:27:33 pm »
New plugs fitted - F'all difference!  :indifferent:
Offline omeydz
  • -Receive: 50
« Reply #22 on: May 29, 2014, 07:40:46 pm »
Were any of the old plugs sooted up more than the others?
Worth a read too:
http://chrisebnerttec48261.blogspot.co.uk/2010/08/injector-patternsdelivery-volume.html
You need to do the injector test I suggested earlier. I think its pointing to wiring +/- ECU.
afaik injector wiring is straight swap plug and play.
About £60 from the dealers according to google.
Current Rides
SOLD
2008 Audi A5 3.0TDI
Offline mtj2k
  • 1.4 TSi GT
« Reply #23 on: May 30, 2014, 09:15:52 am »
@ Omeydz - thanks for the tips but not sure if i can be bothered to strip it again just now.
Weird that i cleared the fault code (0302 - Cyl. 2 misfire) and then i couldn't get it to misfire this morning. As if the fault code was causing it??  :rolleye:
Offline omeydz
  • -Receive: 50
« Reply #24 on: May 30, 2014, 10:09:25 am »
Hope the misfire stays away!!! Good luck :)
Current Rides
SOLD
2008 Audi A5 3.0TDI
Offline mtj2k
  • 1.4 TSi GT
« Reply #25 on: June 02, 2014, 11:30:06 am »
So could hardly get it to mis over the weekend  :happy2:
Not sure if the fuel flush, new injectors, spark plugs or just re-seating the coils as none of them had any immediate improvement!
I reckon it was a sticky valve or lifter
Offline omeydz
  • -Receive: 50
« Reply #26 on: June 02, 2014, 11:32:27 am »
Good to hear!!  :happy2:
Current Rides
SOLD
2008 Audi A5 3.0TDI
Offline 56OctyVRS
  • -Receive: 72
« Reply #27 on: June 02, 2014, 11:56:00 am »
If you have changed the plugs it may have been an incorrectly torqued up old spark plug allowing the  compression by; which can cause running issues and misfires.
Offline mtj2k
  • 1.4 TSi GT
« Reply #28 on: June 06, 2014, 06:35:48 pm »
Well that was shortly lived  :confused:
if anybody has the expertise of interpreting VCDS logs. I did one of 2 WOT runs in 3rd gear today as per APR's misfire spec.
Any help is always appreciated.
http://www.biltonsilver.co.uk/biltonsilver/wp-content/uploads/2012/Run%202%20WOT%203rd%20Gear.xlsx
Offline omeydz
  • -Receive: 50
« Reply #29 on: June 06, 2014, 08:14:17 pm »
Just took a look.
Same numbers for each respective cylinder at each timestamp?
So was the engine not misfiring during your tests? or misfiring by the exact same rates constantly.
(When I had a jammed injector I was watching the measuring blocks for misfire and had kept watching the numbers and my culprit injector threw misfires on that cylinder.)
Current Rides
SOLD
2008 Audi A5 3.0TDI
