Author Topic: RCD 310 into MK5 GTI  (Read 4550 times)
Offline Nico2904
« on: May 27, 2014, 03:54:22 pm »
What do I need to fit a RCD 310 in my Mk5 GTI from 2006? Will it drain battery and is newer canbus gateway required? If so which one to get
Cheers :happy2:
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
Re: RCD 310 into MK5 GTI
« Reply #1 on: May 27, 2014, 04:23:26 pm »
You will require a gateway
I can offer new Pre-coded gateways for £75 delivered
Cluster and Key coding
Location Great Yarmouth
Offline Nico2904
« Reply #2 on: May 27, 2014, 08:29:24 pm »
I've read that it is possible to reprogram the old canbus gateway?! Btw I have acces to VCDS
Offline daedos
« Reply #3 on: May 27, 2014, 08:42:50 pm »
Good value just for the gateway. Is that £5 extra for the coding?  Otherwise your signature needs updating.
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
« Reply #4 on: May 28, 2014, 10:31:03 pm »
Can't reprogram older gateway's
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #5 on: May 29, 2014, 08:59:37 am »
it is £5 for the coding
Offline Nico2904
« Reply #6 on: May 29, 2014, 05:32:11 pm »
Will this gateway, part # 1K0907530T be ok to use with a RCD310 with no issues? Or do you recommend any specific gateway?
Seems people are talking about the "L" one
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #7 on: May 29, 2014, 05:42:17 pm »
I have a Q gateway which I'm selling cheaper £50 delivered, can be pre-coded
Offline Nico2904
« Reply #8 on: May 29, 2014, 06:27:13 pm »
Will that work no probs? Are there any differences in the gateways, i.e there are so many. L, Q, T, AA and so on?!
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #9 on: May 29, 2014, 06:31:24 pm »
Yes will work fine
Offline Nico2904
« Reply #10 on: May 29, 2014, 06:55:13 pm »
Ok I'll take it  :happy2: do you have paypal?
Offline joolstdi
« Reply #11 on: June 02, 2014, 03:36:09 pm »
i thought thant the RNS310 would work with the older canbus without any issues
with no battery drain.
Offline DamoP
  • -Receive: 115
  • 2007 Edition 30 number 1242
« Reply #12 on: June 02, 2014, 04:21:57 pm »
nope, all the newer VW head units require a new can bus, unless your lucky enough to get an RNS510 with correct firmware
MDI Armrest & Glovebox kits
Armrests, cloth and leather
Offline J400uk
  • -Receive: 27
« Reply #13 on: June 02, 2014, 07:29:23 pm »
RNS 310 does seem to be fine oddly enough. I've yet to read any reports of it causing battery drain and I left mine parked for over a week recently without issue. I've got an ancient 1K0 907 530 F gateway.
Could it be because its made by a different manufacturer? Its loosely based on the hardware of the old RNS 300 too whereas the others were all new units when they came out.
