Author Topic: Spec is: 8.5x19 5x112 ET45  (Read 581 times)
Offline Johnny_tro
« on: May 27, 2014, 08:32:28 pm »
Is this ok for a mk5? Straight forward bolt on
Offline GTI.Dav
Re: Spec is: 8.5x19 5x112 ET45
« Reply #1 on: May 27, 2014, 08:34:33 pm »
Yes mate will bolt straight on.
Offline Johnny_tro
« Reply #2 on: May 27, 2014, 08:35:47 pm »
Worried 5 door + family etc these will scrape/catch
Offline GTI.Dav
« Reply #3 on: May 27, 2014, 08:50:52 pm »
Depends on your suspension set up? I'm on air and have the same spec wheels. When driving around at normal height I've never rubbed. When aired out I can lay frame tucking the wheels all round with no arch work.
Offline George10
« Reply #4 on: May 27, 2014, 10:19:16 pm »
I've ran this spec on a fair few wheels and never rubbed. Adding a slight bit of stretch helps with clearance but you'll be fine.
dansmith180
« Reply #5 on: May 27, 2014, 11:55:06 pm »
As long as you use 225 tyres you'll be fine
Offline Johnny_tro
« Reply #6 on: May 28, 2014, 08:55:48 pm »
I'm running standard GT TDi Suspension.
How do you mean add little extra stretch??
Will these sit just inside the arches? if I dropped it down a little
