Author Topic: Air con fault  (Read 3371 times)
Offline lordbigsack
Air con fault
« on: May 29, 2014, 09:30:21 pm »
got the car scanned yesterday to see what the aircon fault is.  Report says electrical problem with the pressure sensor
00819 - High Pressure Sensor (G65): Open or Short to Ground
Anyone know where this is located on an edition30?
Looking to get the part number from it to see if i can source one to maybe swap it out myself, assuming it isnt integral to holding the gas in lol.
Standard Edition 30
Offline J400uk
  • -Receive: 27
Re: Air con fault
« Reply #1 on: May 30, 2014, 12:03:59 am »
Can be DIY fitted but difficult to access as the Ac pipe gets in way. It's basically the sensor that tells the car whether there is sufficent refrigerant gas. Failures aren't unheard of and there is a TPI out for its replacement. Part number 1K0 959 126 D for the latest revision. Not too expensive.
Offline paulw123
  • -Receive: 47
Re: Air con fault
« Reply #2 on: May 30, 2014, 09:54:59 am »
TPI ? whats that when its at home, in my world that's teeth per inch.....  :popcornsoda:
Offline J400uk
  • -Receive: 27
Re: Air con fault
« Reply #3 on: May 30, 2014, 10:57:04 am »
technical product information, it's a document distributed to vw workshops advising on diagnosis/ replacement
Offline OEM+ DUB
Re: Air con fault
« Reply #4 on: May 30, 2014, 12:02:28 pm »
As said above, not difficult to replace, just awkward due to the lack of space.  I changed mine out last year due to a similar fault code.  The union that the pressure switch screws onto is like a tyre valve, when you unscrew the sensor it self-seals and when you install the new one it depresses and opens the valve again.  You shouldn't need a re-gas unless the system has been leaking through the faulty pressure sensor.
Hope this helps!
OEM+ 2005 GTI DSG (high factory standard spec and upgraded with S3 alloy hubs, S3 alloy wishbones, Bilstein B8s and VWR springs by my own hands) owned since 2008 and still loving it!
Offline lordbigsack
Re: Air con fault
« Reply #5 on: May 30, 2014, 08:15:57 pm »
thanks for the replies guys i'll give VW a ring for the cost.  Hopefully the garage will do it while its getting serviced.
Glad to here its self sealing, had visions of it flying off and putting a hole in the bonnet.
Standard Edition 30
