Author Topic: Rear coilover adjustment  (Read 2024 times)
Offline Kalpesh
« on: May 31, 2014, 07:47:49 am »
Hi all,
Wantvto lower the rear of my golf a touch more, am I right in thinking you remove the bolt holding the rear control arm in place so the spring comes out, make any adjustments reinstall spring and connect the control arm back up?
Offline biffobear
Re: Rear coilover adjustment
« Reply #1 on: May 31, 2014, 10:31:18 am »
depending on the make of coilover, you might have to remove the adjuster completely to get it low enough
Offline Kalpesh
« Reply #2 on: May 31, 2014, 10:31:56 am »
FK coilovers
Offline biffobear
« Reply #3 on: May 31, 2014, 11:15:09 am »
I think they can go low
Offline Kalpesh
« Reply #4 on: June 04, 2014, 07:27:01 am »
Will try and get round to it this weekend, one thing I have noticed the adjusters are on the bottom, can they be flipped around so that they are on the top so adjusting in the future is easier?
Offline biffobear
« Reply #5 on: June 04, 2014, 04:53:22 pm »
Yes, that should work ok
Offline SurreyED30
« Reply #6 on: June 05, 2014, 08:22:59 am »
you cant with FK coilovers mate, i asked the same question when mine where fitted by the VAG garage near me. AP's etc can have the adjuster at the top but for some reason the FK kit has to be in the Control Arm  :laugh: someone will explain the truth behind it hopefully, its a pain in the butt i know haha
Jake
Offline jaffa
  • -Receive: 44
« Reply #7 on: June 05, 2014, 11:54:01 am »
iv thought about swapping mine to the tops but it only takes me 5 mins a side to drop it out and adjust it anyway so never bothered
« Reply #8 on: June 05, 2014, 12:39:38 pm »
thats how i did mine when i adjusted my kw v1
