Author Topic: Rns 510 in 56 plate gti  (Read 2606 times)
Offline TaylorGTi
« on: May 31, 2014, 08:44:54 pm »
Iv heard I need a can gateway if I install the rns510 satnav is this true cheers
R-tech Stage 2+ Pirelli Gti
Offline skard
  • -Receive: 245
Re: Rns 510 in 56 plate gti
« Reply #1 on: May 31, 2014, 08:55:35 pm »
The safe answer is yes you'll need a new gateway. However, as 56 plates were into March 2007 you may have the non battery drain variant of a K version gateway, or even an L. Only way is to check or have it scanned with VCDS
Offline TaylorGTi
« Reply #2 on: May 31, 2014, 09:15:07 pm »
Can you fit gateways yourself?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #3 on: May 31, 2014, 09:17:20 pm »
I can offer new pre-coded gateways for £75 delivered
Cluster and Key coding
Location Great Yarmouth
Offline Shaw
« Reply #4 on: May 31, 2014, 09:23:28 pm »
Mine is an '07 and suffered battery drain. :(
'07 Mk5 GTI Manual
Offline Little_Dave
« Reply #5 on: May 31, 2014, 09:26:57 pm »
Depends.... I had an rns510 on my 54 plate with a modified firmware and never had an issue with battery drain, depends where you get the unit from and if it can be changed over or wound back so to speak  :happy2:
Offline doylebros
downsideup
« Reply #7 on: June 01, 2014, 07:14:54 am »
This apparently is a modified version of the 4020 firmware for units with battery drain issues
I installed it on my 07 with L gateway and it worked a treat.
http://www.rnsfirmware.com/firmware-4020-for-older-units-in-europe-with-hdd-rations-60355/
After stick v10 maps on.
Offline skard
  • -Receive: 245
« Reply #8 on: June 01, 2014, 10:04:48 am »
^^I have that and I thought the only modification was to change the disk partitioning percentage?
You have an L unit so nothing to worry about.
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
« Reply #9 on: June 01, 2014, 11:31:47 am »
For the sake of what EDDIE-NL charges for a coded Gateway i would replace it as you then have the flexibility if you decide to upgrade the firmware at a later date.
Offline Viking
  • -Given: 17
  • -Receive: 47
« Reply #10 on: June 01, 2014, 11:36:55 am »
Yep, doesn't modify for battery drain.  :happy2:
Sarcasm for free. Anything after that can only be considered as a bonus.
Just because you think you know something, doesn't make you an expert if you've just read it on the internet, y'know.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #11 on: June 01, 2014, 12:04:35 pm »
and when you sell the car you can swop back to the original gateway. And sell the newer gateway
