Author Topic: Sticking Clutch Pedal - HELP ! - *Update*  (Read 19402 times)
Offline MancBen
« on: October 22, 2009, 09:46:13 am »
Morning chaps,
Over the last couple of weeks my clutch pedal has started to get a bit sticky. It is slow to return to position from the bottom of it's movement... it's got to the point now that sometimes I need to flick it back up with the top of my foot. The clutch itself (Bite etc) seems fine, if you know what I mean.
When I stick it in neutral and pump the clutch I can hear a squeeking / creaking noise.
I had it in my local independant earlier this week having the MAF replaced, but (sod's law) I couldn't replicate the clutch issue.
Any idea's... before I have to take it in to VW at £85 plus VAT per hour (gulp)
Cheers,
Ben  :smiley:
(It's a 55 plate manual Gti on 21K)
« Last Edit: October 28, 2009, 03:05:53 pm by MancBen »
Re: Sticking Clutch Pedal - HELP !
« Reply #1 on: October 22, 2009, 08:39:00 pm »
Any ideas chaps.  :smiley:
Offline chungster
« Reply #2 on: October 22, 2009, 10:21:01 pm »
change the clutch fluid perhaps??
Offline john_o
  • -Given: 136
  • -Receive: 108
    • My Car Blog
« Reply #3 on: October 22, 2009, 10:25:38 pm »
not wishing to be cheeky but check your carpet / mats arent getting in the way.
as chungster says a fluid change may help.
is it worse after multiple pumps of the pedal ??? (cue forum hilarity....)
55 plate / 22k , its probably just not enough use  :grin:
« Last Edit: October 22, 2009, 10:33:10 pm by john_o »
Red ED35 5dr DSG
BLOG | BUILD
Offline cuprak1
  • Cupra k1 - 360 bhp/360 ft-lbs
    • London web design
« Reply #4 on: October 23, 2009, 09:07:38 am »
mine gets stuck a bit in same situation, i just ignored it till this thread.. so bumpage again
SpeedStats iPhone app  - AVAILABLE NOW!
View my Cupra k1 project thread here! 360is
Offline MancBen
« Reply #5 on: October 23, 2009, 01:46:11 pm »
Carpet/Mats are fine
Brake Fluids changed 2 months back (They share the same fluid don't they ??)
Indeed, I think I have made it worse after my recent multiple pumping session !  :grin:
I reckon it's a shagged slave/master cylinder - Booked in at VW next Wednesday. Fingers crossed :scared:
Offline MancBen
« Reply #6 on: October 23, 2009, 02:06:27 pm »
gazbutS3 - I can't read PM yet apparently ???
But I did get a e-mail notification... So in reply to your message:
Thanks for the advice.. I've used Awesome before (on a past SEAT LCR) but VW Stockport are almost walking distance, so for practical reasons it makes sense for them to do the diagnosis... who does the work is another matter.. I usually use Prosport though.
Offline MancBen
Re: Sticking Clutch Pedal - HELP ! - *Update*
« Reply #7 on: October 28, 2009, 03:10:23 pm »
News from VW is that the Slave Cylinder / release bearing is fooked.
Quote to fix : £650.52  :sad1:
Have asked the dealer to see if VW UK will give me some support... the service chap was pretty optimistic, but it will take some time to get a decision.
Anyone else got support from VWUK when the car was out of warranty ? (Has VW service history though.. which apperently will work in my favour)
Ben
« Reply #8 on: October 28, 2009, 03:17:28 pm »
ive never heard of VW uk covering anything out of warranty unless it was a common fault.
If it is a common fault, then yes, the payment from VW UK can be made or broken on the service history
Offline cuprak1
    • London web design
« Reply #9 on: October 28, 2009, 03:19:53 pm »
how much  just for the part and DIY the fix?
Offline MancBen
« Reply #10 on: October 28, 2009, 03:20:35 pm »
Fingers crossed I get somebody in a good mood then.
Offline MancBen
« Reply #11 on: October 28, 2009, 03:23:03 pm »
DIY... you're joking right ?
If VW UK won't play ball, then I will get plenty of quotes... but this is never a job I'd consider myself able to do.
Offline cuprak1
    • London web design
« Reply #12 on: October 28, 2009, 03:24:26 pm »
where are you located mate ?
i have an audi tech who will fit it no trouble, just spoke to him and he said its easy enough.. certainly not that much you were quoted
« Last Edit: October 28, 2009, 03:28:24 pm by cuprak1 »
Offline MancBen
« Reply #13 on: October 28, 2009, 03:49:20 pm »
Heaton Mersey, Stockport.
...and you ?
Offline cuprak1
    • London web design
« Reply #14 on: October 28, 2009, 03:51:33 pm »
...and you ?
London. If i got a price for how much he would want to change it etc would you want that info?
