Author Topic: After an new air filter...  (Read 2694 times)
Offline anderson9
« on: June 03, 2014, 09:13:33 pm »
Any suggestions on which one to buy, don't want to spend to much. Thanks in advance
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
Re: After an new air filter...
« Reply #1 on: June 03, 2014, 09:14:15 pm »
OEM does the job  :happy2:
Offline anderson9
« Reply #2 on: June 04, 2014, 08:46:15 am »
So no need for an upgrade ? Just after a bit noise
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #3 on: June 04, 2014, 08:58:01 am »
Ahhhh you never said you were after an upgrade  :laugh:
Search function is your friend. EVOMS or ITG Maxogen are the best for noise and performance. Hit YouTube for videos of the noise  :happy2:
Offline anderson9
« Reply #4 on: June 04, 2014, 09:21:51 am »
Sorry for the bad description, thanks mate!
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
« Reply #5 on: June 04, 2014, 12:19:46 pm »
What is the best panel filter to get please?. Want to keep the o.e look. :smiley:
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #6 on: June 04, 2014, 12:22:07 pm »
I ran a K&N panel and it was great. Slight increase in performance and throttle response
« Reply #7 on: June 04, 2014, 01:30:26 pm »
OEM paper filter is fine.  :happy2:
Offline Gene Hunt
  • -Given: 59
  • -Receive: 61
« Reply #8 on: June 04, 2014, 01:42:56 pm »
.........thanks. :happy2: Running that now just wondered if any of the '' performance panel filters'' were any better?.
« Reply #9 on: June 04, 2014, 03:16:47 pm »
I used to use an ITG panel filter in the past and felt something extra vs the oem paper one.
Offline SurreyED30
« Reply #10 on: June 04, 2014, 06:19:40 pm »
VWR make panel filters mate, I've rear there quite good but around £40-£50 mark iirc
Offline alexharvey
« Reply #11 on: June 04, 2014, 09:32:41 pm »
im sure the VWR panel filters are made by ITG
Offline SurreyED30
« Reply #12 on: June 05, 2014, 08:11:50 am »
^ correct mate
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #13 on: June 05, 2014, 12:20:01 pm »
Didn't I answer that above?
Offline 56OctyVRS
  • -Receive: 72
« Reply #14 on: June 13, 2014, 10:06:04 am »
I ran a paper filter at stage 2+ and it ran perfectly fine. Tried performance filters and there was no perceivable difference. Just change your cilter every 10k and you will be fine.
On my current car I have tried K&N and Pipercross and I still cant feel any difference in performance over std.
If you research independent filter tests; there is a 0.90% pressure drop difference between the highest flowing filter and the std paper filter. That means there is very little flow difference between them all.
