Author Topic: Help with another proxy airbag light!  (Read 5443 times)
Offline J12spk
  • VW PERVERT
« on: June 03, 2014, 10:33:00 pm »
Evening,
Right had the drivers side impact airbag sensor changed and we checked the loom for damage (was fine) after a vcds fault. All fixed so i thought anyway 2 days later the airbag light cam on again  :sad1:
Took it too a pal but his vcds was out on a job, so we used his fault reader and came up with the following
Multi tester pro
15 airbag (1 fault found)
01638 left rear side airbag crash sensor-G256
Defect
Permanent fault (01638 174)
Unfortunately he has 2 skip lorries turn up to repair so I left him too it, can any1 shed any light on this situation and point me in the right direction?
James
 :fighting2:
Das Auto
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
Re: Help with another proxy airbag light!
« Reply #1 on: June 03, 2014, 10:50:32 pm »
Hiya James,
Fancy meeting up - i'll have a wee look for you :)
PM Me
Offline J12spk
  • VW PERVERT
« Reply #2 on: June 04, 2014, 07:02:24 am »
Text ya later bud
Das Auto
Offline J12spk
  • VW PERVERT
« Reply #3 on: June 04, 2014, 07:27:06 pm »
Anybody shed some light on this?
Das Auto
Offline J12spk
  • VW PERVERT
« Reply #4 on: June 06, 2014, 10:49:27 pm »
No? Fair enough!
Das Auto
Offline SI-R32
  • -Receive: 125
Re:
« Reply #5 on: June 06, 2014, 11:13:30 pm »
The post from the bloke above offered to help out, did you not take his offer up?
Offline J12spk
  • VW PERVERT
« Reply #6 on: June 07, 2014, 09:36:13 am »
Yea ant is guna scan with vcds as he lives near me but just wondering if anybody knew anything about his fault/sensor!
Das Auto
Offline SI-R32
  • -Receive: 125
« Reply #7 on: June 07, 2014, 10:48:42 am »
when you changed the crash sensor, did you actually cancel the fault code, as just renewing it will not clear the original code
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #8 on: June 07, 2014, 10:51:35 am »
Fault code was cleared, I had a quick look at the wiring near the rubber gaitor but couldn't see any damage.
Cluster and Key coding
Location Great Yarmouth
Offline Llew
  • -Given: 45
« Reply #9 on: June 07, 2014, 12:04:39 pm »
Was it a new crash sensor from dealer?
Golf 2006 tdi 140pd, dsg paddles,blue interior led lights,r32 rear bumper, cruise control,vcds,highline , r32 mfsw steering wheel, gti front bumper,miltek decat.
Offline Llew
  • -Given: 45
« Reply #10 on: June 07, 2014, 12:17:12 pm »
Oh I read it wrong I thought it was the same sensor
Offline J12spk
  • VW PERVERT
« Reply #11 on: June 07, 2014, 07:23:37 pm »
Lol no, Ed replaced the sensor with the initial fault and cleared the error. 2 days late a new fault on a new sensor!
Das Auto
Offline Sie
« Reply #12 on: June 07, 2014, 07:35:06 pm »
There is a plug on the loom. Under the seat solder it up properly and heat skrink and yellow tape. Was a link to a VW repair sheet for it some where, sorted my problem.
Simon
Fettled Laser Blue '05 GTi 5dr
Offline Llew
  • -Given: 45
« Reply #13 on: June 07, 2014, 08:01:07 pm »
I had mine come up about a month ago I cleared it and it hasn't come back - hoping it's the same in your case
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #14 on: June 07, 2014, 08:09:41 pm »
Simon
the problem is with the sensor, not the airbag in the seat
