Author Topic: Drivers door won't unlock with fob.  (Read 4495 times)
Offline howie1987
  • -Given: 92
  • -Receive: 20
« on: June 08, 2014, 03:26:57 pm »
As title really. Its only the drivers side doesn't open inless i use the key.
Everything else works and its only started doing it.
Any ideas ?
Offline slider955i
  • you are only here once so enjoy
Re: Drivers door won't unlock with fob.
« Reply #1 on: June 08, 2014, 08:24:12 pm »
 i had this and had to have lock changed by vw in the end , you can do it yourself but bit of a job
gt sport 170 tdi , p - torque stage 1 map 208 bhp 338 ft lb
powder coated gunmetal alloys and caliper colour change
Offline howie1987
  • -Given: 92
  • -Receive: 20
Re: Re: Re: Drivers door won't unlock with fob.
« Reply #2 on: June 08, 2014, 08:32:30 pm »
it still unlocks when i use key though. So dont think its the locks. Must be somthing electric, some sort of module ?
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
« Reply #3 on: June 08, 2014, 09:03:48 pm »
Had the same problem with mine which turned out to be a broken can bus wire in the door loom. Easy to fix if not a bit time consuming.
Offline Tortaruga
  • -Given: 36
  • -Receive: 105
'07 Red manual
Offline howie1987
  • -Given: 92
  • -Receive: 20
Offline Wragg
« Reply #6 on: June 09, 2014, 07:09:00 pm »
Had the same problem with mine and it didn't recognise the drivers door had been or was open..
New lock solved it.. Glad it wasn't a module as there was non in the country at the time, and it was still under warrantee..
Offline howie1987
  • -Given: 92
  • -Receive: 20
Re:
« Reply #7 on: June 12, 2014, 06:45:10 pm »
Its just started working today so god knows what was wrong.
Offline slider955i
« Reply #8 on: June 12, 2014, 07:12:38 pm »
dont get caught out mine played up , then ok for a while , then played up again
Offline howie1987
  • -Given: 92
  • -Receive: 20
Re:
« Reply #9 on: June 12, 2014, 07:35:36 pm »
Going to get it checked out anyway. Need aircon checked aswell think then pressure switch sensor seal or switch itsself is gone.
