Author Topic: Intermittent ABS fault?  (Read 1233 times)
Offline RobboGTI
« on: June 08, 2014, 08:51:56 pm »
Hi guys! I have an intermittent fault that I guess is ABS related? Three orange warning lights on the dash.
 Dirty sensors maybe?
The fault could never appear for ages and then will appear every journey for a few days or every other day.
Is there a simple way to stop this from popping up again?
Any help or suggestions would be appreciated
Rob
Re: Intermittent ABS fault?
« Reply #1 on: June 08, 2014, 11:09:29 pm »
You know this already but you need to get the car scanned.
Offline RobboGTI
Re:
« Reply #2 on: June 09, 2014, 11:07:26 am »
Just thought as it was intermittent there might be something loose or needs checking or cleaning.
Something I can check myself first without costing me
Sent from my C6903 using Tapatalk
Offline grey golfster
  • -Given: 79
« Reply #3 on: June 09, 2014, 12:20:32 pm »
Mines just done this at 90k.
Rear wheel bearing gone, apparently not an unusual fault?
Whel location was id by scan.
Re:
« Reply #4 on: June 09, 2014, 01:00:16 pm »
Checked to see if any member with a vcds cable is located in your area and willing to help?
http://www.mk5golfgti.co.uk/forum/index.php/topic,120.msg812454.html#msg812454
Offline RobboGTI
Re: Re: Re:
« Reply #5 on: June 09, 2014, 02:37:42 pm »
thank you for your help there!
Offline hugo
« Reply #6 on: June 12, 2014, 01:16:38 am »
This happened to me! After a car wash and on mine it's the wiring loom on drivers side wheel! Some wires where striped and damaged!
