Author Topic: Golf GT Tdi 2004 broken down  (Read 956 times)
Offline chakatee
« on: June 08, 2014, 10:39:53 pm »
Hi,
Hope someone can help.
Golf MK5 GT Tdi 2004.
Tonight, I was driving my Golf and on a straight bit of road accelerated quickly. Once reaching around 50-60mph, heard a very loud bang (may have been from left-hand side). The car then lost acceleration and I stopped at a set of traffic lights with the engine ticking over. The car was spluttering for the next 20 yards with hardly any acceleration at all. There was a lot of smoke from the rear. There are no engine management lights on. I switched the engine off then on again. There was a brief, unusual smell inside the car when I started revving the car. The engine splutters badly and the rev counter is erratic, not reaching very high revs.
The car idles as it did before the loud bang.
I called the RAC and the mechanic noticed that the mass air flow hose and loose and virtually detached. He re-secured this but no improvement when the accelerator pedal was pressed - still the very bad misfiring and awful revs.
The car has been re-mapped in the past - around 4 years ago.
The car has experienced some lumpy idling/slight misfire in recent past which improved after regular use of Shell V-Power Nitro.
The car has had a replacement turbo in the past about 3 years ago (by Awesome Gti). At lot of other work was done at the same time.
The car is no longer drivable and has been towed to a nearby garage.
Any advice would be greatly appreciated.
Thanks.
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
Re: Golf GT Tdi 2004 broken down
« Reply #1 on: June 08, 2014, 10:52:04 pm »
Sorry if it's a stupid question but have you checked the charge pipe or (can't remember the correct names for them) inter cooler pipes haven't come popped off?
Offline chakatee
« Reply #2 on: June 08, 2014, 11:45:46 pm »
No, haven't checked intercooler pipes. It went straight to the garage. I'm just worried it's going to coast an arm and a leg to fix. It couldn't have happened at a worse time :(
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
« Reply #3 on: June 14, 2014, 02:14:03 pm »
Just out of interest - did the garage manage to sort fix the car?
