Author Topic: Boot doesn't poop open with fob  (Read 1122 times)
Offline TaylorGTi
« on: June 12, 2014, 08:26:59 pm »
Car unlocks and locks fine but the boot doesn't pop open using the fob
Any help much appreciated!
R-tech Stage 2+ Pirelli Gti
Offline Malyon
Re: Boot doesn't poop open with fob
« Reply #1 on: June 12, 2014, 08:41:26 pm »
It doesn't pop as standard you have to do mod.
Just boot unlock
Offline vwrascal
« Reply #2 on: June 12, 2014, 09:07:47 pm »
You need to hold the boot release button on the fob down for a couple seconds, If it still doesn't pop then it needs a quick click with vcds, softouch release  :happy2:
Offline SRC
  • -Receive: 27
« Reply #3 on: June 13, 2014, 08:31:42 am »
Middle button on the fob needs holding down a bit longer.  I think it only works when the car is locked - not when the driver's door is already unlocked.  When you've opened it that way, the car locks itself when you close the boot, so never put your keys in the boot!
Shadow blue DSG 5 door with leather, sunroof, 18" Monzas, MFSW.
Full list of mods:  Seat inserts and a VW bottle opener.  Each worth 20bhp.
Offline TaylorGTi
« Reply #4 on: June 13, 2014, 02:23:07 pm »
Yeah pop was wrong word open is the correct term lol... I'll give it a go if not I'll "pop" to stealers  :booty:
Offline Carbon Goodies
« Reply #5 on: June 13, 2014, 04:09:26 pm »
If you look carefully I think it was poop that was the wrong word lol!!!
Offline john87
  • -Receive: 53
« Reply #6 on: June 13, 2014, 06:27:29 pm »
The button on the fob (when the car comes from the factory) simply allows the boot handle to be used without fully opening the car, i.e. the other doors.
However, this function can be modified via VagCom (VCDS) in order to operate the boot latch solenoid, which will in turn allow the boot to 'pop' open once different struts, pins and bump stops are fitted (search for 'boot pop mod' or similar) - the required parts can be easily sourced from Skoda/Seat dealers  :happy2:
