Author Topic: Exhaust System Fault - any ideas?  (Read 650 times)
Offline berg
  • -Given: 49
  • -Receive: 38
« on: June 12, 2014, 11:33:21 pm »
Hi guys, driving along dual carriageway tonight and as i flawed it in 4th gear out of roundabout car made slight noise and felt like it was being held back, almost like the tyres were scrabbling for grip on an uneven surface. then realised it was exhaust fault when symbol started flashing on the dash.
slowed down and then on fulll throttle at 2500 rpm in 5th it would do it again, like exhaust gases struggling to get out as you pressed the loud pedal more.
any ideas - lamda sensor? i have full 3" pipewerx tbe.
ta
Re: Exhaust System Fault - any ideas?
« Reply #1 on: June 13, 2014, 12:23:02 am »
Did it feel like you hit a brick wall Andy?
Offline Scottymon
  • -Given: 83
  • -Receive: 125
  • UnNaturally Aspirated
« Reply #2 on: June 13, 2014, 12:49:39 am »
He's gauging at throttle body death with that promotion.. If so you'll most likely have the EPC light on with reduced power... Replace with revision Q or later, its a bit of pita to swap due to location but a relatively easy DIY, did mine for £70... Been good for 6 months at stage 2.
Offline berg
  • -Given: 49
  • -Receive: 38
« Reply #3 on: June 13, 2014, 09:07:07 am »
hi guys, no EPC light did not show up just the emissions control one in that list there, it flashed for 30 seconds or so then went off.
I have oem pcv on as sold the BSDH upgrade but it is not the latest revision. It felt like you were scrabbling round in mud,
So what we thinking more likely to be PCV than throttle body?
Offline john87
  • -Receive: 53
« Reply #4 on: June 13, 2014, 07:16:19 pm »
coil packs?
Mines died in this way when one of the coils packed in (no pun intended)
« Reply #5 on: June 13, 2014, 08:51:00 pm »
Ok Andy, you need a scan...   :smiley:
Offline berg
  • -Given: 49
  • -Receive: 38
« Reply #6 on: June 13, 2014, 11:09:24 pm »
Yeah will be Monday now ayoub, as pipewerx left laptop with vcds at home today doh and not sure of any really local members who could scan it for me? Eccie or Jason-rmh maybe...
« Reply #7 on: June 13, 2014, 11:37:34 pm »
Are they not open tomorrow?
Offline vRSAlex
  • -Receive: 253
« Reply #8 on: June 14, 2014, 01:57:40 pm »
If the engine light is flashing then its a misfire.
Follow AKS tuning on Facebook
