Author Topic: RCD 510 and CANBUS upgrade but still Powerdrain  (Read 10911 times)
Offline remigi
« on: June 15, 2014, 01:56:06 pm »
Hi guys,
I am from Australia; however, I was hoping to get some answers on here as I am not having much luck with my problem on the Australian forums.
I have replaced my 1K0 970 530 E CAN gateway with a 7N0 970 530L to try and stop the battery drain from the RCD510; however, I am still getting a slow drain. After one week the car takes a while to start, after two weeks the battery is dead.
I am trying to find out if it is incorrect coding on my behalf. I have one constant malfunction, that is Module 61: Battery Regulator. I don't have a battery regulator and so i UNTICKED it in the installation list; however, it is still showing up in the Auto-Scan. How do I code it out totally so that it no longer shows up in the Auto-Scan.
Is it possible that the CAN gateway is not going to sleep because it is looking for this battery regulator module thats not there? How can I code it out of the Auto-Scan....?? - As you can see below, its in the auto-scan list at the top, but then does not show up in the actual scan.
I also decided to test the RCD510 with my original gateway as I have never done this since getting the radio (Read next section)
In addition as another test I added my ORIGINAL 1K0-907-530-E gateway back into the car yesterday. The battery was at 12.57V and this morning it was at 12.28V. I then tested the current draw after 35 minutes. I locked the bonnet with a screw driver to make the car think it was locked, remove the negative battery terminal and connected it to in series with my multimeter. At the start I was getting a draw of 1.75-2.00Amps, then after 35 minutes I was getting 0.00-0.03Amps being drawn. I watched this for 5 minutes and it did not change... however, this does not make sense since this gateway should not be compatible at all... is it possible that the current draw jumps back up at a later stage?
AUTO-SCAN From NEW GATEWAY 7N0-907-530-L
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine        Labels: 06F-907-115-AXX.lbl
   Part No SW: 1K0 907 115     HW:
   Component: 2.0l R4/4V TFSI G00 0070
   Revision: --H01---    Serial number: VWZ7Z0D1249466
   Coding: 0403000318070160
   Shop #: WSC 00046 412 00000
   VCID: E3EBF27C22B8F306665-80B6
1 Fault Found:
005634 - Power Supply Terminal 30
               P1602 - 002 - Voltage too Low - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: -40.0∞C
                    Absolute Pres.: 0.0 mbar
                    Voltage: 0.000 V
Readiness: 0000 0001
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No: 1K0 907 379 K
   Component: ESP FRONT MK60      0104
   Coding: 0004738
   VCID: 3A55EF1875B252CE953-806F
No fault code found.
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 1K0 907 044 AB
   Component: ClimatronicPQ35 066 0404
   Shop #: WSC 00000 000 00000
   VCID: 67F3666C56801F263AD-8032
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 1K0 937 049 N    HW: 1K0 937 049 N*
   Component: Bordnetz-SG     H34 0803
   Revision: 00H34000    Serial number: 00000001360578
   Coding: E58D0F260004180000140000140000000009FF0F64
   Subsystem 1 - Part No: 1K2 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0401
   Coding: 00049109
   Shop #: WSC 00000
   Subsystem 2 - Part No: 1K0 955 559 M  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 005  0605
   Coding: 00480286
   Shop #: WSC 00000
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 C    HW: 1K0 909 605 C
   Component: 32 AIRBAG VW8   013 2100
   Revision: 02013000    Serial number: 0033HD03HV67
   Coding: 0013106
   VCID: 2C79D9408FE6FC7E17F-8079
   Subsystem 1 - Serial number: 6332MSME0818182ED
   Subsystem 2 - Serial number: 6342MSME08261125/
   Subsystem 3 - Serial number: 6351HSME0524425B0
   Subsystem 4 - Serial number: 6361HSME052D401D6
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 G    HW: 1K0 953 549 G
   Component: Lenks‰ulenmodul 021 0050
   Coding: 0002042
   VCID: 364DFB2841AAB6AE71B-8063
   Subsystem 1 - Part No: XXXXXXXXXXX
   Component: Lenkradmodul    004 0030
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1K6 920 860 E
   Component: KOMBIINSTRUMENT VDD 0812
   Coding: 0003703
   Shop #: WSC 13166 001 1048576
   VCID: 3041CD30A3CE989E2B7-8065
Address 19: CAN Gateway (J533)       Labels: 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 L    HW: 1K0 907 951
   Component: J533  Gateway H41 1620
   Revision:   H41       Serial number: 170212F1000337
   Coding: 350003
   Shop #: WSC 00768 768 00768
   VCID: 3957F014B0B459D69C9-806C
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VDD 0812
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
   Part No: 1K0 959 701 E
   Component: Tuersteuergeraet 09 0148
   Coding: 0000052
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 H
   Component: EPS_ZFLS Kl.0       1502
   VCID: 3147C834A8C49196249-8064
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 BL
   Component: 01 KSG              0301
   Coding: 91C802087F2D8505485FC69010
   Shop #: WSC 50620 812 60948
   VCID: 7BDB2A1C3A08ABC6CE5-802E
   Subsystem 1 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H03 1301
   Subsystem 2 - Part No: 1K0 907 719 B
   Component: Neigungssensor  004 0003
   Subsystem 3 - Part No: 1K0 951 177
   Component: Innenraumueberw.004 0101
1 Fault Found:
01134 - Alarm Horn (H12)
            004 - No Signal/Communication
Address 47: Sound System        Labels: 3C0-035-456.lbl
   Part No: 1K6 035 456
   Component: 08K Audioverst.     0003
   Revision: 00002000    Serial number: 00000000009777
   VCID: E9F7E054C094A956AC9-80BC
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
   Part No: 1K0 959 702 E
   Coding: 0000052
Address 56: Radio (J0503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 5K0 035 190 A    HW: 5K0 035 190 A
   Component: Radio RCD510  051 0207
   Revision: 00000001    Serial number: VWZ1Z3L8071483
   Coding: 0101000001000E
   Shop #: WSC 00020 790 12345
   VCID: 236B327C22383306A65-8076
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN1.lbl
   Part No: 1K0 959 703 C
   Component: Tuersteuergeraet 06 0213
   Coding: 0000016
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN1.lbl
   Part No: 1K0 959 704 C
   Coding: 0000016
End   ---------------------------------------------------------------------
AUTO-SCAN from ORIGINAL GATEWAY 1K0-907-530-E -0110
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
Readiness: 0110 0101
   Coding: 0004738
   Coding: 00049109
   Shop #: WSC 00000
   Coding: 00480286
   Shop #: WSC 00000
   Coding: 0013106
   Coding: 0002042
   Coding: 0003703
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 E    HW: 1K0 907 951
   Component: Gateway         H09 0110
   Revision: 09          Serial number: 2700104C020EBA
   Coding: 3D3F0342070003
   Shop #: WSC 12345 123 12345
   VCID: 297720548014E956EC9-807C
   Coding: 0000052
2 Faults Found:
01299 - Diagnostic Interface for Data Bus (J533)
            005 - No or Incorrect Basic Setting / Adaptation - Intermittent
   Coding: 0000052
   Coding: 0000016
   Coding: 0000016
Thanks!!!
Remi
Offline daedos
Re: RCD 510 and CANBUS upgrade but still Powerdrain
« Reply #1 on: June 15, 2014, 05:08:53 pm »
Interesting you should post this, I'm in a similar position. Where did you get you RCD510 and CAN from?
Offline DamoP
  • -Receive: 115
  • 2007 Edition 30 number 1242
« Reply #2 on: June 15, 2014, 06:14:27 pm »
maybe pm eddy-ml, he has coded hundreds of can buses so can spot an issue off a mile away
MDI Armrest & Glovebox kits
Armrests, cloth and leather
Offline doylebros
« Reply #3 on: June 15, 2014, 07:57:58 pm »
As above says Ed would be my first port of call.
However,the alarm fault could cause the drain once you lock the car - was the drain test done with the car lock?
Offline remigi
« Reply #4 on: June 16, 2014, 03:32:35 am »
I got my RCD from a forum member here in Australia. It is the Bosch version with RVC connection but no USB. - I do not have RVC installed.
I got my CAN from Bold-Sport.com; however, as mentioned at the moment my original CAN is back in the car. How long does it usually take for the battery to drain if there is the battery drain issue? I hopped in my car this morning and it started fine, even though I have my original 1K0-907-530-E 0110 gateway installed.
So strange!
I am not sure about the alarm fault, thats a strange one in it self considering the Siren works. I tested it yesterday by putting down the window, locking the car and then setting it off by waving my hands inside the car. This suddenly came up after an Accident I had in 2012 where the front of my car sustained some damage. It was minimal, Radiator etc.. did not need to get replaced, just the plastic bumper, lights, fogs etc...
The drain test was done with the car locked in the following fashion.
1. Open Bonnet
2. Lock bonnet latch using screw driver
3. Lock Car
4. Disconnect negative battery terminal
5. Connect positive multimeter lead to negative battery terminal
6. Connect negative multimeter lead to negative battery cable (now physically disconnected from battery)
7. Turn multimeter to 10A setting and observe reading.
As mentioned, the reading started at 1.75-2.00Amps for about 2 minutes then it rapidly dropped to 0.2-0.35 then I left the car. I came back after 35 minutes and it was reading between 0.00-0.02, going up and down. I observed this for 5 minutes and then disconnected it all, im not sure if it would have spiked again.
In regards to Eddy-NL, hopefully he see's this post. I tried coding out the battery regulator module for hours and hours... I have not been ablt to do it. At the moment the new gateway is just sitting here on my desk useless. Although, maybe I don't even need it? But I cant believe that my original E gateway magically works and no one else's does... its all a bit weird.
Essentially I used to be able to leave my car for 1 month and it would still start..
The battery is relatively new, March 2013 and has only been draining totally once.
Offline daedos
« Reply #5 on: June 16, 2014, 06:43:09 am »
My drain is intermittent - can vary between 1.2, and 0.04A.  Maybe yours is too. Therefore it can vary how long it'll take to drain - 3 days, a week, longer.  From what I understand 40mA (0.04A) is the expected value for a mk5 Golf.
Here is a TSB on testing for battery drain:
http://pics.tdiclub.com/data/500/TSB_27_08_04_Matrix.pdf
FYI I found my car's power draw would settle after about 3 minutes. Therefore it was fairly easy to pull fuses and confirm the radio is at fault somehow (fuse #19 in engine bay).
Offline remigi
« Reply #6 on: June 16, 2014, 07:12:11 am »
Its a bit difficult to do as I do not have any of that equipment, nor do I have a VAS.
I was also told that pulling out fuse #19 in the engine bay does not confirm that this is a radio fault because when you pull the fuse out it wakes up the CAN gateway and therefore increases the current flow again. I may be wrong....?
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #7 on: June 16, 2014, 10:44:35 am »
If you have a multimeter you can check the fuse with mV setting
The other thing is that on cars with the sound system installed can prevent battery drain
I saw another golf with sound system and old gateway and that didn't drain either
« Last Edit: June 16, 2014, 10:46:52 am by Eddie-NL »
Cluster and Key coding
Location Great Yarmouth
Offline daedos
« Reply #8 on: June 16, 2014, 10:55:31 am »
Pulling fuses will wake the car up, so you give it a few mins to sleep again.
Is there a trick to fooling the car in to thinking the driver's door is shut? Just flicking the lock didn't work.
downsideup
« Reply #9 on: June 16, 2014, 11:12:49 am »
Someone had a similar problem on another thread and it turned out he had the wrong battery installed in his car.
Might not be your problem but worth checking just in case.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #10 on: June 16, 2014, 11:53:30 am »
strange worked for me when the car is locked
Offline remigi
« Reply #11 on: June 16, 2014, 12:12:56 pm »
Woooww! Ok, that could clarify it... really? I have a sound system installed... I think? I have a AMP under the passenger that looks like this.
Offline remigi
« Reply #12 on: June 18, 2014, 12:29:29 am »
Hi Eddie-NL
I was wondering if you could clarify if the above picture is the AMP that you are talking about? If so, that is what I have in my car. Do you believe that this is why I am not experiencing battery drain? Were Amps not standard in all GTI's? (I got this car second hand, so I am not sure of the options that were put on)
In addition, is there any reason you can think of why I cannot code out the module 61-Battery-Regul. in the new 7N0-907-530L CAN-Gateway I got? I have unticked it in the installation list; however, it still appears in the Auto-Scan list as a malfunction, I assume this is what could be causing the battery to drain over 2 weeks? (Note: currently I have put my original E gateway back in as a test)
Offline J400uk
  • -Receive: 27
« Reply #13 on: June 18, 2014, 07:36:41 pm »
Very strange problem. Haven't heard of the battery regulator or seen the underseat amp. Didn't think VW offered a sound system with the Golf Mk5 in the UK at least.
Offline daedos
« Reply #14 on: June 19, 2014, 10:20:12 am »
Part of the VW soundpack I think - page 9 on the mk5 options list - www.goo.gl/UewyO.  Check for the amp + if fuse slotted #18 in the engine bay is filled.
The Battery Regulator is an interesting point - any more info on impact?
