Author Topic: After market head unit (Satnav, DVD And Audio ) for MK5 GTI  (Read 13375 times)
Offline Bennz
Hi all,
I have seen few videos that people replaced the factory CD player with those aftermarket touch screen devices .
Does anyone know which one of those are the best ( with blue backlit to match the rest of lights) ? And easiest to install without messing around much ?
I want to be able to use the satnav feature with voice guidance , could I use the radio antenna or needs to install an antenna somewhere ?
I don't plan to spend much on that, just something that is better than the OEM simple CD player.
Offline TaylorGTi
Re: After market head unit (Satnav, DVD And Audio ) for MK5 GTI
« Reply #1 on: June 17, 2014, 05:24:11 pm »
There's ones on ebay that use android operating system... I'm buying on next month so will let you know the score.
I did have one in my 1series coupe and it was as good as I think you'll get. Personally I I used an oem one last week and didn't really like it..
R-tech Stage 2+ Pirelli Gti
Offline Bennz
« Reply #2 on: June 17, 2014, 10:48:31 pm »
Which one is it ?
Do they have global maps or need to download or purchase maps separately ? Do you install GPS antenna or uses the radio one ?
You getting one with OBD2 ?
Offline DanMaytee
« Reply #3 on: June 18, 2014, 10:01:58 am »
I have this one https://www.youtube.com/watch?v=eVqDMQXNXnQ
It's £260 from here http://www.ebay.co.uk/itm/Volkswagen-GOLF-EOS-GOLF-JETTA-PASSAT-7-HD-Car-DVD-Player-GPS-Nav-Radio-Touch-/120947427862?pt=UK_Audio_TV_Electronics_In_Car_Entertainment_GPS_In_Car_Audio_Players_PP&hash=item1c29074a16
All plug and play and worked perfect for the two years I've had it.  Only downside is with any aftermarket headunit in the Mk5 is you'd need to run a switched live from the fuse box or 12v socket to the yellow cable at the back of the headunit for it to turn on and off with the key.  Of course if you don't mind pressing the power button when you want to turn it off and on you'll have no problem.
Offline Dave7692
« Reply #4 on: June 18, 2014, 10:11:08 am »
Sorry to thread hijack but can you get updated maps for that?
If so I might have to consider it.
Offline ekaJ
« Reply #5 on: June 18, 2014, 10:14:12 am »
I have an android head unit, got it for a bargain price of £180!
It's pretty good, not as slick as a quality aftermarket but the amount of features is crazy.
Wifi dongle, access to play store, dvb-t tuner.
Would deffo recommend one :)
Offline DanMaytee
« Reply #6 on: June 18, 2014, 10:18:28 am »
Yeah, it runs WinCE so if you want you can even run TomTom on it.
Offline Bennz
« Reply #7 on: June 18, 2014, 11:32:53 am »
Could you post a link ?
Offline steven0555
« Reply #8 on: June 18, 2014, 01:23:10 pm »
I have this one:
Works well. No rewiring required and also works with the steering wheel controls. To get a decent radio reception I had to use one of these:
 http://www.amazon.co.uk/Celsus-AAN2128-Antenna-Adaptor-Amplifier/dp/B004V89HJM/ref=sr_1_3?ie=UTF8&qid=1403093624&sr=8-3&keywords=fakra
Was pretty simple to wire up(blue wire needs wired into switched live which can be taken from ISO connector) and signal is back to near oem levels.
Steve
Offline Bennz
« Reply #9 on: June 21, 2014, 03:29:14 am »
With the units you mentioned do you get voice navigation ? Do you pay extra for map updates ?
Do you get car info if using OBD2?
Offline markt
« Reply #10 on: June 21, 2014, 12:34:15 pm »
Mine came with 1 of these when i bought the car works a treat never had any problems. Satnav works as it should and the bluetooth streaming from my phone is an added bonus
Offline Bennz
« Reply #11 on: June 21, 2014, 02:11:11 pm »
Which one is yours mate ?
I probably end up getting Eonon D5152 and get Igo8 navigation software with NZ maps ( from where I don't know yet .. )
Offline markt
« Reply #12 on: June 21, 2014, 02:43:09 pm »
 I have this 1 Funcionts of VW Golf Passat car dvd gps, car radi…:
Offline markt
« Reply #13 on: July 01, 2014, 10:38:31 am »
This is the same as mine if your still after 1 ebay item 201117705784
Offline Bennz
« Reply #14 on: July 01, 2014, 09:09:01 pm »
I went with Eonon D5152 and waiting for it to arrive
