Quote from: xjay1337 on July 03, 2014, 10:53:47 pmVrscarl I missed in your other post but you need to use a high speed on a rotary. Or it won't do anything. I removed some serious wiper marring on my old windscreen with ceriglass and rayon pads. Check my detail for my car in the pro detailers sectioYou can damage the windscreen sure, but so can you damage any material you're polishing. :)I did my own windscreen with a rotary with the Ceriglass Kit and i got great results at 700rpm. My car was only a couple of years old though and i reckon 700rpm is faster than i could do it with the hand pads they supply It was more to remove the GTechniq G1 sealant though which i just don't rate so i could apply another.I was advised by a few pro detailers not to go with a high setting. But if it worked for you then its something i can bear in mind for future reference.
