Author Topic: MK6 Golf R error code,rev's up and down on it's own!  (Read 2161 times)
Offline sanj
  • -Given: 17
« on: June 22, 2014, 03:28:10 pm »
When fully warmed up I have the following problem in that at idle the rev's go upto 2000rpm and then a few second's later down to 1000rpm and then doe's the same thing over and over,run's fine with no engine light's or loss of power,on a VCDS scan it came up with the following:-
1 Fault Found:
001287 - Idle Control System RPM
               P0507 - 001 - Higher than Expected. - Intermittent
             Freeze Frame:
                    Fault Status: 00100001
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 76484 km
                    Time Indication: 0
                    Date: 2045.14.22
                    Time: 17:22:09
             Freeze Frame:
                    RPM: 1081 /min
                    Load: 14.9 %
                    Speed: 0.0 km/h
                    Temperature: 89.0°C
                    Temperature: 57.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 13.716 V
Readiness: 0000 0000
Any idea's anyone?Was serviced at VW over a week ago.
Offline Llew
  • -Given: 45
Golf 2006 tdi 140pd, dsg paddles,blue interior led lights,r32 rear bumper, cruise control,vcds,highline , r32 mfsw steering wheel, gti front bumper,miltek decat.
