Author Topic: Boost pipe part number and rough price  (Read 5710 times)
Offline Airz182
« on: June 22, 2014, 09:05:25 pm »
Im going to replace one of my boost pipes because i think its leaking,
The pipe is one the driverside at the bottom, theres a metal boost
Pipe then, it clips into a rubber boost hose,
Its the rubber pipe i think is leaking near the clips,
Does anyone know the part number for this pipe and how much they roughly cost thanks
Instagram- airz182
  • -Receive: 453
Re: Boost pipe part number and rough price
« Reply #1 on: June 22, 2014, 09:09:38 pm »
I suspect you want part 9 1K0 145 832E
Offline Airz182
« Reply #2 on: June 22, 2014, 09:32:45 pm »
Thats the one thanks, can them seals be bought seperatley??
Instagram- airz182
Offline Airz182
« Reply #3 on: June 22, 2014, 09:34:38 pm »
Also are these pipes the same as the diesel ones?
Instagram- airz182
  • -Receive: 453
« Reply #4 on: June 22, 2014, 10:12:06 pm »
O ring seals can be got separately.
I suggest you change them first before getting the new IC hose as the hose isn't cheap when compare to the cost of the o rings (around £3.50)
Offline Markyed30
« Reply #5 on: June 23, 2014, 09:02:54 pm »
http://www.mk5golfgti.co.uk/forum/index.php/topic,81510.0.html
Just the o ring the new part number is in there sorted mine and made a difference
Offline Airz182
« Reply #6 on: June 23, 2014, 09:07:41 pm »
Cheers mate, the pipe looks in decent condition tbh hardly any movement and clips all seem fine, so guessing it could be the seals, u checked the dv calce on sunday and its rev g, and looks almost new, car seems to boost but just a tad laggy and seems to make more woooooassttt noise!!! Than used to
Instagram- airz182
Offline Airz182
« Reply #7 on: June 26, 2014, 11:07:07 am »
Can i get seals off ebay? Or anywhere online
Instagram- airz182
Offline jason_rmh
  • -Given: 69
  • -Receive: 81
Re:
« Reply #8 on: June 26, 2014, 11:44:51 am »
If anyone's interested I found the part no's for the 2.0 tdi (BKD) as I have the same issue:
O-ring going into intercooler on the passenger side 2 X 3C0 145 117H - 61.90mm
the other side of this pipe 4 X 3C0 145 117F 57.85mm
O-ring turbo to metal intercooler pipe 2 X 3C0 145 117 - 43.95mm
Thanks to mortygttdi as he posted this info in another thread.
Jas
VCDS (Preston, Lancashire)
Offline Markyed30
« Reply #9 on: June 26, 2014, 03:39:13 pm »
Offline Airz182
« Reply #10 on: June 26, 2014, 03:43:19 pm »
http://www.shop4volkswagen.co.uk/product/Parts_3C0145117H
I got mines from there
The link you give me mate, is that for the actual seals to order or a link to just the site?
Ive clicked it and it just says washer in the description, no pics or anytging cheers
Instagram- airz182
Offline Airz182
« Reply #11 on: June 26, 2014, 04:53:28 pm »
Anyone got a offer code aswell!!!!
Instagram- airz182
Offline Markyed30
« Reply #12 on: June 26, 2014, 07:55:25 pm »
If you look at the reference code it matches the number in my post, that's the actual part you need iv linked I ordered 2 incase it happend again but lost it already  :signLOL:
Offline Airz182
« Reply #13 on: June 26, 2014, 08:53:50 pm »
Cheers mate appreciate that
Instagram- airz182
