Author Topic: Chinese Bluetooth unit  (Read 1604 times)
Offline usmangti
« on: June 23, 2014, 11:20:16 pm »
What is the difference between this;
http://www.ebay.co.uk/itm/OEM-Bluetooth-Interface-Module-9W2-FOR-VW-Volkswagen-RNS510-RCD510-1K8-035-730-D-/310782526885?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item485c1505a5
And the ones that crop up on here for 4x the price?
I'm considering one if it can provide handsfree calling and music streaming.
Usman
Offline V2 FAN
  • Porsche 911 inbound
Re: Chinese Bluetooth unit
« Reply #1 on: June 23, 2014, 11:37:05 pm »
It's not enhanced VW bluetooth. You can not dial or pick up phone from your radio touchscreen. You will have to use your phone  or multi functional steering wheel to call out or pick up phone calls. Hence why Ehanced VW bluetooth costs considerably more.
My advice is to avoid  :happy2:
« Last Edit: June 23, 2014, 11:44:29 pm by V2 FAN »
Offline usmangti
« Reply #2 on: June 23, 2014, 11:44:19 pm »
Thanks for the feedback. :happy2:
I quite like the idea of using the steering controls, does that mean it will display telephone book on the MFD?
there's so many Bluetooth module threads, would be awesome for someone with the knowledge to breakdown it down part number and features if you know what I mean
Offline V2 FAN
« Reply #3 on: June 23, 2014, 11:48:57 pm »
I don't think this will display on your MFD.
This is a very basic bluetooth module with limited controls, it will work with the MFSW in terms of answering or cancelling a call but that's it. You will have to use your phone for selecting who to call which defeats the purpose of Bluetooth to a certain extent.
Your options are to buy an older VW Bluetooth kit compatible with redline as the newer ones are not or the Fiscon kit which if I was you I would go for.  The Fiscon also gives you an added display in your menu which shows oil temp and other features.
You need to check thou what limitations may impact on you should you be using a lowline display  :wink:
Offline usmangti
« Reply #4 on: June 23, 2014, 11:52:28 pm »
Yeah your right it's pointless if can't select contacts or dial numbers.
Also didn't realise fiscon had Bluetooth features I thought it was just the added temp and boost gauges!
I will have a highline MFD fitted very soon :happy2: red display (red dot?)
Offline V2 FAN
« Reply #5 on: June 23, 2014, 11:54:27 pm »
Have a look
http://hazzydayz.com/vw-fiscon-bluetooth-handsfree-kit-1277-p.asp
I'm not recommending these guys but it gives you a better understanding
Will look good with your new High line  :happy2:
Offline DamoP
  • -Receive: 115
  • 2007 Edition 30 number 1242
« Reply #6 on: June 24, 2014, 05:29:46 pm »
MDI Armrest & Glovebox kits
Armrests, cloth and leather
Offline J400uk
  • -Receive: 27
« Reply #7 on: June 24, 2014, 07:03:43 pm »
Haven't seen these cheap Bluetooth units from China before. You are right that they normally cost a lot more, even used ones are £100+
Wonder if they would definitely support EU head units or if its restricted to the similarly cheap Chinese market RCD 510
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #8 on: June 25, 2014, 08:18:37 pm »
The phone modules are the very basic
You need a highline to use them and you need to be able to do the wiring too
Had some come to me to who bought one and had the local garage fit it
wiring was all wrong and when I sorted that had to tell them they needed a highline which they didn't have.
So best avoided, cheapest is not always best
Cluster and Key coding
Location Great Yarmouth
Offline DamoP
  • -Receive: 115
« Reply #9 on: June 25, 2014, 08:27:45 pm »
