Author Topic: ABS Sensor problem?  (Read 6104 times)
Offline charlieb76
ABS Sensor problem?
« on: June 24, 2014, 10:50:14 pm »
Hi all,
Just wondering if someone might be able to help me diagnose a fault.
A couple of weeks ago while driving along normally the ABS, ESP and Tyre Pressure lights all lit up on the dashboard. The lights come on once the car is up to about 30mph or so and then remain on until the car is switched off
I took it to the local VW garage and got them to run a diagnostic check.
The following error was returned:
Number           VAG00287: Right rear ABS wheel speed sensor
Error type 1     mechanical malfunction
Error type 2     Intermittent
As a result of the findings I asked my local garage to change the wheel speed sensor on the right rear wheel. When doing so he found that the coil spring was damaged and so also replaced that.
I have just got the car back and the lights are still coming on once the car is up to speed!!  :confused:
Any ideas on what my next steps should be??
Many thanks..
Offline Monkey10
Re: ABS Sensor problem?
« Reply #1 on: June 25, 2014, 06:55:18 am »
Hi, check the pick up ring on the wheel bearing, you'll more than likely find a small metal deposit stuck to the pick up ring so will just need cleaning or the worst case scenario the pick up ring will have started to lift/corrode so a new wheel bearing will be needed. Cheers
Offline doylebros
« Reply #2 on: June 25, 2014, 06:41:12 pm »
This is worth a read for general eduction
http://www.scottishvag.net/viewtopic.php?f=5&t=75097&view=print
Pretty much what above say although you can't see the reluctor ring on the mkv!
Offline charlieb76
« Reply #3 on: June 26, 2014, 07:47:28 pm »
Booked in tomorrow for further analysis by the steelers! Will let you know what they come back with...
Offline cass
« Reply #4 on: June 26, 2014, 10:45:44 pm »
Wheel bearing mate just changed my rears. Threw up the same code as your for one of them
Offline grey golfster
  • -Given: 79
« Reply #5 on: June 27, 2014, 09:24:13 am »
Monkey 10, + 1.
Cover/seal on my bearing is damaged, not the bearing itself.  Hence abs signal generator is dead.
Bearing itself ok.
Poor/compromised design imo!
In garage this morning, appx £200, total 1 side.
