Author Topic: intermittent stutter possible cause?  (Read 1008 times)
Offline asht42
« on: June 26, 2014, 07:51:20 am »
Right then guys and gals, had an odd intermittent stutter the last few weeks and have just discovered that the rubber gromet on the pipe circled wasn't sealing properly, can anyone tell me what it does and whether it could cause the issue in question?
Just as a side note, the following parts are brand new:
Diverter valve
coilpacks
spark plugs
just been serviced
2007/57 gti dsg
No lights coming up on dash
had codes read before came up misfire, hence coilpack replacement
Offline asht42
Re: intermittent stutter possible cause?
« Reply #1 on: June 26, 2014, 08:39:29 am »
Or better yet anyone near me with vdcs?
Offline edd666999
  • -Receive: 89
« Reply #2 on: June 26, 2014, 08:55:53 am »
Everyone could be near you....or no one. Without a location its pretty impossible to tell!
look here:
http://www.mk5golfgti.co.uk/forum/index.php/topic,120.0.html
Offline asht42
« Reply #3 on: June 26, 2014, 10:12:25 am »
Cheers and updated profile  :sad1:
Offline asht42
« Reply #4 on: June 29, 2014, 10:15:43 am »
http://wiki.ross-tech.com/wiki/index.php/16825/P0441/001089
had matto plug her in (many thanks btw definitely worth the trip) and this is what came up guessing being as my carbon canister lid is loose thats the problem
Offline j4ymo
« Reply #5 on: July 01, 2014, 09:46:15 pm »
hi I'm new here but have been a mechanic for more years than I like to recall the item you have highlighted looks like the vacuum pipe from the vacuum pump which shouldn't really give any stutter problems by leaking as they are not in any way connected to the inlet tract but i have known the vac pumps to seize get it lookd at asap
