Author Topic: Will a USA Gti highline work in a mk5 golf  (Read 2094 times)
Offline Rob1
  • -Given: 40
  • -Receive: 24
« on: June 26, 2014, 08:46:19 am »
Hi all I am currently looking at a set of highline clocks from a USA Gti, does anyone know if they would work in a mk5 uk golf . The part is correct i.e. 974 replacing a 964 midline, I have read a topic previously relating to USA clocks but not sure if that was on this or another forum.
Thanks Rob1
Black Ed30
Offline skard
  • -Receive: 245
Re: Will a USA Gti highline work in a mk5 golf
« Reply #1 on: June 26, 2014, 08:52:04 am »
Yes, but the foils will say degrees in F not C, they also have words instead of pics for some things such as BRAKE.
You could swap your foils over though.
I had US diesel clocks in my old car, there as an oil sensor that needed activating too so there may be some small changes to make.
Offline J400uk
  • -Receive: 27
« Reply #2 on: June 26, 2014, 12:40:56 pm »
As above watch out for the oil sensor setting, I had that on a cluster I bought for another car. Without changing that the ECU may permanently log a fault code for 'no communication with instrument cluster'
Offline Rob1
  • -Given: 40
  • -Receive: 24
« Reply #3 on: June 26, 2014, 07:20:56 pm »
Thanks for feedback guys, I'm currently contemplating the usa one as opposed to a uk spec one
Black Ed30
Offline Dave J
  • -Given: 45
  • -Receive: 63
« Reply #4 on: June 26, 2014, 08:27:33 pm »
Works in my car a treat, but EddieNL fitted them  :notworthy: I asked him to swap the foils so that it looked like a UK cluster - I didn't like the USA 'BRAKE' & 'CRUISE' type where we have symbols...
Edition 30 - no. 1387
Offline Rob1
  • -Given: 40
  • -Receive: 24
« Reply #5 on: June 26, 2014, 09:09:00 pm »
nice one just what I wanted to hear, how long ago did Eddie fit them?
Also what are the foils?
« Last Edit: June 26, 2014, 09:13:33 pm by Rob1 »
Black Ed30
Offline skard
  • -Receive: 245
« Reply #6 on: June 26, 2014, 09:16:06 pm »
Foils are the printed circles with your speedo range, RPM range, fuel gauge and water temp, i.e., the round bits behind the needles.
Easy to swap the US for UK ones...if you are careful removing the needle.
I did this to my old car in late 2009, sold the car with them in 2012.
You have nothing to worry about, if they are cheap then go for it.
Offline Rob1
  • -Given: 40
  • -Receive: 24
« Reply #7 on: June 26, 2014, 09:34:59 pm »
Black Ed30
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #8 on: June 26, 2014, 09:57:44 pm »
I have them fitted and quite like the Brake, cruise words on the dash, as its different looking !
Silver is the way !
