Author Topic: car wont start when hot!! Update: ECU at fault  (Read 3133 times)
Offline jameelno1
  • TDI Power
« on: June 26, 2014, 06:32:02 pm »
UPDATE: Ecu at fault does anyone know who can rebuild ecu's in the midlands area
recently my car wont start when warm, cold start is fine starts straight away. i have the traction control light on and esp light. when i turn my key to ignition the engine light does not come on either plus the temperature gauge has a mind of its own
ive taken it to various garages all baffled ive had the following changed:-
crank sensor
engine temperature sensor
glow plug relay
new battery
none have rectified the problem. a vw parts specialist stated that my Ecu needs a reset as it might be blocked or ecu might have gone  :confused:
this is my last vagcom check wont scan now either with vagcom
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 7D
VIN: WVWZZZ1KZ4W074497   Mileage: 146840km/91242miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Sporadic communication error 1000
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Cannot be reached 1100
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine        Labels: 03G-906-016-BKC.lbl
  Part No SW: 03G 906 016 B    HW: 028 101 147 8
  Component: R4 1,9L EDC         5645
  Shop #: WSC 01287 785 00200
  VCID: 22405DE2FDD4D03
No Faults Found
 or DTCs not supported by controller
 or a communication error occurred
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
  Part No: 1K0 907 379 K
  Component: ESP FRONT MK60      0103
  Coding: 0021121
  VCID: 3A7085827544B83
2 Faults Found
01314 - Engine Control Module
           013 - Check DTC Memory - Intermittent
           004 - No Signal/Communication
Address 08: Auto HVAC        Labels: 1K0-820-047.lbl
  Part No: 1K0 820 047 CB
  Component: Climatic PQ35   080 0201
  Shop #: WSC 00000 000 00000
  VCID: 66C801F2517CEC3
1 Fault Found
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-M.lbl
  Part No SW: 1K0 937 049 K    HW: 1K0 937 049 K*
  Component: Bordnetz-SG 1.0 H30 0701
  Revision: 00030000    Serial number: 00000000444002
  Coding: 00890F0600041800001400001400000000
  VCID: 37769CB64656A5B
  Subsystem 1 - Part No: 1K2 955 119 B
  Component: Wischer VW350  012  0401
  Coding: 00065493
  Shop #: WSC 00000
2 Faults Found
02395 - Parking Light Right Front (M3)
           012 - Electrical Fault in Circuit
Address 15: Airbags        Labels: 1K0-909-605.lbl
  Part No SW: 1K0 909 605 A    HW: 1K0 909 605 A
  Component: 0M AIRBAG VW8   022 0500
  Revision: 04022000    Serial number: 0033FD07GZ5B
  Coding: 0012365
  Shop #: WSC 01268 785 00200
  VCID: 2A50B5C285E4083
No fault code found.
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
  Part No SW: 1K0 953 549     HW: 1K0 953 549
  Component: Lenks?ulenmodul 012 0030
  Coding: 0000002
  VCID: EFE6E4D6FE86ADB
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
  Part No: 1K0 920 950 L
  Component: KOMBIINSTRUMENT VDD 3554
  Coding: 0001401
  Shop #: WSC 00578 210 64257
  VCID: 3162A2AEA8327BB
1 Fault Found
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
  Part No SW: 1K0 907 530 C    HW: 1K0 907 951
  Component: Gateway         H08 0080
  Revision: 08          Serial number: 21001041105134
  Coding: 3D0F0B40070003
  VCID: 27564CF696F635B
3 Faults Found
01305 - Databus for Infotainment
            Freeze Frame:
                   Fault Status: 01100100
                   Fault Priority: 1
                   Fault Frequency: 76
                   Reset counter: 67
                   Mileage: 146831 km
                   Time Indication: 0
                   Date: 2000.00.00
                   Time: 00:07:47
01304 - Radio
            Freeze Frame:
                   Fault Priority: 2
                   Fault Frequency: 76
                   Reset counter: 67
                   Mileage: 146831 km
                   Time Indication: 0
                   Date: 2000.00.00
                   Time: 00:07:51
           004 - No Signal/Communication - Intermittent
            Freeze Frame:
                   Fault Status: 00100100
                   Fault Priority: 2
                   Fault Frequency: 9
                   Reset counter: 107
                   Mileage: 146831 km
                   Time Indication: 0
Address 25: Immobilizer        Labels: Redir Fail!
  Component: IMMO                3554
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
  Part No: 1K0 959 701 E
  Component: Tuersteuergeraet 09 0116
  Coding: 0000052
  VCID: 3064A7AAA338723
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
  Part No: 1K2 909 144 E
  Component: EPS_ZFLS Kl.2       1202
  VCID: 2E58B9D2B90C643
2 Faults Found
            Freeze Frame:
                   Mileage: 6800 km
                   Temperature: 23.0?C
                   Voltage: 11.20 V
                   Voltage: 11.00 V
00668 - Supply Voltage Terminal 30
           002 - Lower Limit Exceeded - Intermittent
            Freeze Frame:
                   Mileage: 6800 km
                   Temperature: 26.0?C
                   Voltage: 8.40 V
                   Voltage: 10.20 V
Address 46: Central Conv.        Labels: Redir Fail!
  Part No: 1K0 959 433 C
  Component:    KSG              0201
  Coding: 19E802087F2D8F0F085B0100
  Shop #: WSC 00591 210 68245
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
  Part No: 1K0 959 702 E
  Coding: 0000052
Address 56: Radio
Cannot be reached
Address 7D: Aux. Heat        Labels: 1K0-963-235.lbl
  Part No SW: 1K0 963 235 C    HW: 1K0 963 235 C
  Component: PTC-Element         0404
  Revision: 00600000    Serial number:
  VCID: 2B5EB0C68A1E11B
« Last Edit: June 26, 2014, 08:28:28 pm by jameelno1 »
golf mk5 1.9 tdi
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
Re: car wont start when hot!! Update: ECU at fault
« Reply #1 on: June 26, 2014, 10:24:13 pm »
Never used them myself, but heard good things  :happy2:
http://bba-reman.com/uk/
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #2 on: June 26, 2014, 10:37:34 pm »
Check the wiring to the ECU
Had a similar issue on a 6R polo, turned out to be 2 wires that were damaged
Cluster and Key coding
Location Great Yarmouth
Offline jameelno1
  • TDI Power
« Reply #3 on: June 27, 2014, 11:36:54 am »
will have a look today for any broken wires. ecu gets hot so wont communicate with engine when its cold it starts first time
golf mk5 1.9 tdi
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #4 on: June 27, 2014, 11:59:28 am »
it is not just a case of looking at the wires you need to check them properly.
the polo was the same, would run till it got to temperature then it would cut out.
as the problem got worse it wouldn't start at all and vcds wouldn't communicate with the ECU in the end
Offline jameelno1
  • TDI Power
« Reply #5 on: June 27, 2014, 12:04:12 pm »
thanks thats exactly what my problem is will get the wiring tested then
golf mk5 1.9 tdi
