Author Topic: VW iPod interface not working  (Read 1624 times)
Offline zed4
    • New Forest Sports Car Hire
  • My Ride: 2006 VW Golf GTI DSG
« on: June 29, 2014, 11:46:13 am »
Hi,
We have a genuine VW iPod interface in our 2006 GTI, but it doesn't work. I've taken it out of the car, but apart from a slightly broken iPod connector, there doesn't seem to be anything wrong with it.
It will play a song for a few seconds, but then stops and displays no CD. The head unit is the RCD500. Are they serviceable? Anyone repair them? Or shall we just replace it? Been trying to find a unit which will also add Bluetooth.
New Forest Sports Car Hire  - TVR Chimaera 400, Caterham Roadsport SV 140, Porsche Cayman S, BMW M135i
Offline DamoP
  • -Receive: 115
  • 2007 Edition 30 number 1242
Re: VW iPod interface not working
« Reply #1 on: June 29, 2014, 01:08:35 pm »
these suffer massively with dry solder joints. they arnt serviceable, most people replace them
MDI Armrest & Glovebox kits
Armrests, cloth and leather
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #2 on: June 29, 2014, 01:37:49 pm »
is it in the armrest or is it the retrofit glovebox one?
Cluster and Key coding
Location Great Yarmouth
Offline zed4
« Reply #3 on: June 29, 2014, 02:20:25 pm »
Retrofit glove box one
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #4 on: June 29, 2014, 02:55:20 pm »
I have a new module for £18 delivered
Offline zed4
« Reply #5 on: June 29, 2014, 06:57:19 pm »
Does it have all the cables? The Apple lead on ours was a little crushed from being shut in the glovebox at some point. I'm not sure if this is why ours isn't working yet.
Offline Eddie-NL
  • Trader - 2014
  • -Receive: 298
« Reply #6 on: June 29, 2014, 07:01:26 pm »
i don't have the wiring just a new box
Offline zed4
« Reply #7 on: June 29, 2014, 07:07:45 pm »
Ok, thanks for the offer. I think I'll leave it for now, I'm thinking we might change to the later RCD310 or 510 now. Just need to figure out what I need to install it and to add iPod and Bluetooth.
Offline zed4
« Reply #8 on: June 29, 2014, 07:08:27 pm »
Might need a new gateway from you if we do go for a new head unit.
Offline CarlW
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,92229.msg927100.html#msg927100
« Reply #9 on: June 30, 2014, 05:23:01 pm »
If your going for the full new unit as I have you will need a new CAN gateway as yours Is 2006.. Not guaranteed but worth budgeting for as your probably going to need one, that then needs fitting and coding in. Then comes the new headunit, replace RCD500 with whatever you chose, I've just got the 510 and can honestly say its a great bit of kit. Then like you I have also opted to get the MDI armrest dock from Damian name on here is demon666. Besides them, you will need a fakes antenna adapter as the FM AM antenna is slightly different to that of the RCD300/500 which you can get for around £7 on ebay. Be prepared to spend around £300 - £350 with everything included that you need.
